General steering wheel centre removal
mark78
the horn on my friends punto works now and again i have been tryin to get the centre steering wheel cover off but cant see any screws or anything holding it its a 2007 1.2 anyone help please thanx mark
Including airbags then?
We shall await the arrival of your "How do i get this AIRBAG Error warning light off" thread :shrug:
or "How do i remove the steering wheel cover from my teeth" after the airbag deploys on you if your really unlucky.:tempt:
On a serious note though, dont forget to disconnect the battery before you do this as removal of the connector while they car is powered will result in an error being logged and your airbags disabled. Leaving you a trip to the dealership or to someone with the relevant diagnostic tools to clear the error.
i have the fiat diagnostics tool so airbag light should not be a problem cheers for replys
the tool to put airbag lights out and to read fault codes is that not a diagnostics tool
funny the tool i have put the airbag light out before on the same car so its bound to do it again if needed
Great then, just some of the generics won't do it. Why not just remove the battery terminal first though, leave the car for half an hour and then do the job.
Save recording an error.
