Old 17-02-2010   #1
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Starting problem (revs drop off)
Twice today i have started the car from Cold and i have had it stall the first time or two...
2006 1.2 8V Grande Active No air con 23K ish miles
if i give it a few revs or blip the throttle its fine once started and running i dont have a problem with it stalling
Not had a problem at all since it was new and it worked fine through the recent really cold weather..
what could it be?
thinking coolant temp sensor,
throttle body
damp
Massive gash
Just a little touch up
Old 17-02-2010   #2
Moderator
Andy Monty's Avatar
Re: Starting problem (revs drop off)
had the air box off and the Breather was full of mayo as was throttle body car only does 9 mile runs to and from work so cleaned it all out with a bit of luck that should solve it will see in the morning...
Massive gash
Old 17-02-2010   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
I'd be inclined to measure voltage of MAP sensor.
Thanks Andy Monty thanked for this post
Old 17-02-2010   #4
Moderator
Andy Monty's Avatar
Quote Originally Posted by T14086 View Post
At what point T? during start up?
Massive gash
Old 18-02-2010   #5
I had this on both my alfa's. Each time it was battery related. The first was as a result of fitting too low powered a battery, the 2nd was also too low powered a battery that started doing this when it got older.
In short, replace the battery.
Mayo is normal on all italian cars in this weather. Just the moist air and it accumulates under the filler cap. Go for a long drive and it should clear.
Driving: Alfa GT 3.2 V6 in black and Abarth 595 145bhp in Red.
Ransoman is offline Reply With Quote Quote
Old 18-02-2010   #6
Moderator
Andy Monty's Avatar
Quote Originally Posted by Ransoman View Post
will slap it on my charger tonight and see if it helps tomorrow morning (it has battery recovery pulse charge) But i have had No PAS issues which seems to crop up if the battery is on its way out or flashing mileage
Not so worried about the Mayo just that reading the stilo guides it can cause erratic tick over that's all cant harm cleaning it out
Massive gash
Old 18-02-2010   #7
Moderator
Andy Monty's Avatar
just to confirm this is the MAF sensor?
Name:	 <a href='http://www.fiatforum.com/autolink.php?id=9&script=showthread&forumid=105' target='_blank' title='Mass Air Flow' class='gal'>MAF</a>.JPG
Also just found another earth point which comes off the same loom bunch near the starter motor so gave that a clean up whilst i was at it (can't do any harm)
Massive gash
Old 18-02-2010   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
yes Andy.
How long/attempts does it actually take for the car to start?
Old 18-02-2010   #9
Moderator
Andy Monty's Avatar
yes Andy.
usually 3 or 4 when been stood several hours starts then revs just fall away till it stalls by the 3rd/4th attempt i have my foot on the accelerator to bring the revs up then its fine never had a problem until yesterday.. started fine this morning but then threw a fit tonight at work
have tried this tonight thought it was worth a shot
https://www.fiatforum.com/stilo/1249...ml#post1307417
take it if all else fails i can unplug it as a get me home option and the car will run fine from cold (was warm when i did it tonight)
Massive gash
Old 19-02-2010   #10
Moderator
Andy Monty's Avatar
Just an update tried the above and the car seemed to start OK this morning and tonight and the MPG has come back up so looks like it is the Map sensor
Got one ordered...
Massive gash
Old 20-02-2010   #11
Moderator
Andy Monty's Avatar
EML Light Reset.... (MAP issues)
as per my earlier post i have fitted a new MAP sensor (its a pattern part but looks identical to the OEM Bosch one right down to the casting and marks on the casing without the sticker probably a fatal mistake but we'll see) the MPG has come back up big style and the car starts way better....
i cant get the EML to turn off regardless of which sensor i plug in (the OEM one didn't trigger the EML till i run it unplugged to prove a point)......
Will it self clear after several good runs providing the new sensor is ok?
I have an OBD reader and after running it unplugged i get 2 P code faults one barometric pressure and inlet temp sensor fault as "PENDING" and another for the barometric pressure showing as "STORED"
i reset the ECU and plug the map back in then start the car EML light stays on and the "stored" fault (barometric pressure) comes back
I have just taken the battery off for an hour to see if that does any good?
Any help would be gratefully received
Massive gash
Old 20-02-2010   #12
Moderator
Andy Monty's Avatar
Re: EML Light Reset.... (MAP issues)
well taking the battery off seems to have done the trick.... Car feels like it has more power and the MPG over my usual work run is back to normal
Massive gash
Old 20-02-2010   #13
Forum Moderator
T14086's Avatar
T14086 has donated!
Old 20-02-2010   #14
Moderator
Andy Monty's Avatar
have just knocked up a guide for MAP replacement
https://www.fiatforum.com/grande-pun...placement.html
Thanks Most Easterly Pandas thanked for this post
Massive gash
Old 22-02-2010   #15
Quote Originally Posted by Andy Monty View Post
what could it be?
throttle body
damp
had this problem on grande 1.4 8v 56 reg 27k miles, cured by correcting weak battery connections, fix tight with small 4mm self tapping screw into terminals (the spring loaded standard battery connectors go loose with cold mornings/ age !-) This fix also cured bad/ify starter relay, bad gearchanges from the autologic gear box when in auto mode.
miss's wanted to get rid of car, but since fix loves it once again
rx8h2o is offline Reply With Quote Quote
(T) Problem when starting and holding revs Concpet Punto (Mk2/2b) 3 29-12-2009 13:51
(T) Clunk as the revs drop James1989 Grande Punto 4 21-11-2009 15:06
(T) Fiat punto 1.2 1999 revs drop to nothing tara_1.2 Punto (Mk2/2b) 0 20-07-2008 17:31
(T) Revs drop when I press throttle. HELP!! Plwakefield Coupe 8 27-12-2006 00:42
(T) revs drop when accelerating then stalls teulk Punto (Mk1) 0 29-09-2004 19:06
