Hi
I have searched and seen quite a few steering problems with Grande Puntos. Also there is a current recall for a steering problem as well I notice...
The steering on our '06 GP 1.3d 90 has started to make a grinding noise/vibration when you move the wheel slightly to the left or right, it does this more at low speeds. Spent ages looking for the power steering reservoir......doh! - its electric!
Is this problem anything to do with the recall? Haven't had a recall notice and my wifes name is on the V5.
I will check the VID number later and see if its affected. If it is will this be fixed under recall or is it not the same steering issue?
We have already had to pay for a new engine out of warranty and many other faults, can't believe something else has gone wrong on this car!
