TheBicycle
Hello. I have a 2006 GP Dynamic 1.3 MultiJet 75.
I have no 12V outlet in the boot but I'd like to.
I saw few threads in this forum (https://www.fiatforum.com/grande-punto/156014-found-wire.html) discussing that in most of the GPs, even if there is no outlet connector, there are wires and a pre-cut hole, so in most cases you just have to buy a connector and have it connected with the wires.
I looked in the boot of my GP and indeed there is a pre cut hole on the left side, next to the boot light. There is even a cable (two wires, blue and dark red / brownish) with a very small black and green connector. I thought that this is the 12V cable, but when I measured it (the engine was working during the test) with multimeter, there was no power whatsoever in that wires.
Please, could you tell me if this is the right cable for the rear 12V outlet, and if it is, where the fuse for that cable is supposed to be. I would like to check if there IS a fuse, and it's not blown.
