Hi. I have a big and old problem. I have Grande Punto 1.3 75 hp model. I have modified all the car. Big turbo, exhaust system vs.vs.vs. . I did everything at the car. And i am a chip tuning seller.
I have problem with my car. The problem is about turbo pressure. The car's ECU is not supported high pressures. My chip tuning expert and me worked on this cars ecu for a long time. At the end we only raise up to 1.7 bar but no more...
What happens?
Normally If you boosted up the pressure. If the boost go up to 1.5 bar, the car went into the safe mode. The failure lamp show up and the car can't move than 3000 rpm and no boost upper than 0.5
This is so bad problem for me.
I want to ask all the site. Is there anyone know the solution? How can we change the cut-off. In the map MARELLI we can not find anything about that. So we can not go away from safe mode.
If there is any friend knows something about this or if anyone fix that problem please share. If you know any map tuner can say something to me please tell him or tell me about him.
I am waiting your help. Thank you so much.
What happens?
