im Axle Specialists
Old 12-06-2008   #1
grande punto handbrake cable adjustment
can any one please tell me how to adjust the handbreak cable on a grande punto 1.9 sporting thanks
Grande Punto Sporting 1.9 multijet in red
hardline is offline Reply With Quote Quote
Old 15-06-2008   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: grande punto handbrake cable adjustment
10mm nut behind handbrake lever
Old 15-06-2008   #3
thanks i will have a look
Old 15-06-2008   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
just pull up the cover behind the handbrake...its tight but will lift up
Thanks peter7889 thanked for this post
Old 15-06-2008   #5
So 'T' - you're saying that the adjustment to the handbrake can be done INSIDE the car and all you have to do is pull the back cover off - right?
.......Well I just don't see how that whole plastic surround pulls up and off
- sorry.
Superboy is offline Reply With Quote Quote
Old 15-06-2008   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Superboy View Post
- sorry.
eat porridge, makes you stronger
p.s. I said cover behind the handbrake....either that or I been doing it wrong last 2 years
Old 16-06-2008   #7
So all that time spent down at the gym isn't enough....oh well porridge it is then.
The handbrake lever on a G. Punto is covered in a flexible vinyl cover which moves up and down with the handbrake lever....the whole thing is surrounded by a hard black plastic moulding with a cup/bottle holder to the rear of the handbrake.
Does one remove the flexible vinyl cover?
Old 16-06-2008   #8
Jap Slut
puntokris's Avatar
puntokris has donated!
Its not unusual, it was the same in my mk2, just remove the ashtray behind the lever.
C:\Users\User\Pictures\Type-r
puntokris is offline Reply With Quote Quote
Old 16-06-2008   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
dannyb-with-a-gp knows how to do it;
Quote Originally Posted by dannyb-with-a-gp View Post
Tip: When your giving your car a good clean, do you find it difficult to clean inbewteen the seats and around the handbrake?
Just give the plastic cover, which includes the drinks hold a good yank and it will come off. This gives you loads of space to clean! Then simpily pushes back on. Hope this helps
Old 16-06-2008   #10
Cool
Thank you.
Old 17-05-2011   #11
just a quick note if you punto has the armrest then there is a lumba support switch on the arm rest flip this switch out and this exposes 3 x 10mm nuts undo to remove armrest, now pull handbrake cover from the rear and remove plastic cover around handbrake and this will now expose the handbrake adjust
andyast1976 is offline Reply With Quote Quote
Old 17-05-2011   #12
This post has saved me a lot of time i had images of trying to tighten the hand brake from outside the car.
How tight would you recomend to tension the hand brake ? I don't want it so tight so it is starting to activate before i pull up the lever but i don't like it to have loads of play.
peter7889 is offline Reply With Quote Quote
Old 28-07-2011   #13
mines at the top of its travel. its fine on flat bit on my drive I ain't to confident of it. will be giving this a go tomorrow morning!
rodduz is offline Reply With Quote Quote
Old 08-10-2017   #14
I've just done this and to be honest I struggled at first because I was trying to lift the whole console assembly up with my fingers between it and the carpet.
I quickly figured that this is a one piece lump that would be fixed at the front and wasn't going to budge.
You need to prise the smaller back part (with cupholder) between it and the main base and it comes off easily and you just slide it foward over the handbrake.
Hope this helps others as it wasn't obvious to me from the above.
John
alfistiUK is offline Reply With Quote Quote
(G) Grande Punto windscreen washer adjustment barry m Grande Punto 1 01-05-2008 19:30
(T) mk2 punto handbrake cable on left gone slack ?? PuntoMk2Goldie Punto (Mk2/2b) 3 03-04-2006 14:49
(T) Handbrake Cable Adjustment - How? leightoness Punto (Mk2/2b) 2 16-05-2005 12:56
