Looks real good mate. To be honest that looks quite low already, how much of those springs are you going to see anyway.
looking good might do the same TOP JOB!
good job, looks great. Looks better on the m-jet wheels though
Red the best, it goes with the red badges, especially on a black car
wouldn't it have been better to remove the pads before you painted them
haha, i need to get hold of one, doubt i will get one as cheap as you did!lol, well the full size spare I have in the back is an mjet wheel...just need another 3 now
Yep, red brakes, red badges, black car is awesome combination indeed!!!
I did do this, i wouldnt know where to start. Just be carful when painting and its finewouldn't it have been better to remove the pads before you painted them
yep nice and easy to do when you know how
Jack car up safely axle stand and chock wheels
remove wheel
you need a 13 mm spanner....
a piece of bent welding rod bent into an S shape helps too..
you need to remove both 13mm bolts (which are at the back of the caliper) when you remove them you need to be able to support the caliper (as it will dangle by the rubber hose (not good) hence the S hook hooked onto the suspension spring then hang the caliper on it...
next remove the pads they wiggle/ pull off..
you should also replace the spring retaining clips (they look the same but they aint there are 2 types (look at them closely you will see) so dont get them mixed up..
if you need to replace the disc you need to do more but you dont mention that so i wont go there
now you have the pads out of the holder you need to refit the new ones..
clean the caliper and holder with disc cleaner
its good practice to apply a smear of cera tec grease to the piston edge
http://www.partsforsaabs.com/product_info.php?products_id=2686
you need to reset the piston at this point now i dont know the official fiat method but I do the following
Remove the brake fluid bottle cap (under the bonnet)
cut a piece of wood 2-3" square and about 10mm thick and put this over the piston. then use a g-clamp to press the piston back in
now apply a thin smear of crea tec on the back of the inside pad (the one that sits against the piston) BUT NOT THE OUTBOARD PAD! this has an adhesive backing so peel the white label off and offer up to the caliper next refit the caliper body to the caliper making sure the bolts are tight
refit wheel
lower car
replace top cap on fluid bottle and pump the brakes to adjust the piston to its bite point..
Hope that helps
looks ace... tint it aswell, would look well smart on that colour car
I just painted mine red yesterday looks really nice!
remove wheel
refit wheel
lower car
Hope that helps
