Has anybody fitted these to their GP. Do they make a noticable difference? How much? Have seen them for £20, is this a good price?
I'm going to fit some of these bulbs later today. I'll let you know if they make a noticeable difference. I know Capt. Chaos has got a set of these on his GP too.It's more the actual visible distance that I am interested in.
Great, could you let me know how you fit them too. Had a look and there isnt a lot of room for manouve!
I have seen these bulbs on Ebay and wonder if you think they are any good. They seem to offer either 55w or 100w whats the difference? Also they look very blue, do they look very blue when in use? Again will these side lights look too blue when they are on?
Thanks again
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290141285255
Does changing your lightbulbs not affect your warrenty... :idea:
Just make sure that what ever you buy are UV cut as none UV cut bulbs can cause discolouration of the polycarbonate lense
do you have to remove the battery cover to gain accsess to n/side bulbsSorry Phostead, missed your comment.
Open bonnet![]()
Remove round rubber rear cover, just pulls off, don't drop it!
Before you remove the bulb, look at it from the front, you will see the location 'pips', make a note of their orientation (ath the bottom)
Pull off connector
There is a metal clip that you need to push to one side (can't remember which sorry) then hinge it back which will allow you to pull the bulb out.
Again note orientation (middle connection at the top)
Fit the new one (don't touch the glass), hinge the metal clip up and lock back into position.
Re-fit connector.
Re-fit rear cover.
The nearside (left hand side) is gives easier access.
You cannot really see the metal clip so a lot of it is by 'feel'
Good luck!
