Comment
Guide Tools
<!-- google_ad_section_start -->Converting S2 Abarth Headlights to fit S1 GP.<!-- google_ad_section_end -->
Published by Robert1031
13-12-2009
Unrated
User Rated:Unrated
Step 1 ~ Disconnect and Remove Drivers side headlight unit (Series 1) from car (please note, front bumper panel needs loosening/removing to facilitate headlight unit removal).
Step 2 ~
Remove rubber cap/cover from back of headlight.
Step 3 ~
Disconnect wiring from headlight bulb and then remove bulb. Remove sidelight bulb complete with holder.
Step 4 ~
Remove headlight bulb spring holder, using star drive.
Step 5 ~
Twist 14 pin connector block clockwise and remove via the larger diameter hole.
Step 6 ~
Remove white insert from 14 pin connector block.
(You will notice that only 7 pins are in use out of the possible 14).
Step 7 ~
Please inspect the connector block (see picture immediately below) carefully in order to indentify the locations of the pins relative to the locating lugs etc.
Name:	standard 14 pin.jpg
Step 8 ~
If you intend to re use the old headlights then it is important that you label/number the various wires (using sticky labels?), so that these can be correctly wired to a Series 1 or Series 2 vehicle in future. Trace out the pins above and label the wires with the corresponding pin number.
Step 9 ~
Once all 7 wires have been labelled (see picture immediately below), the ‘wires/pins’ can be removed via the back of the 14 pin connector block. This is done by using a small screwdriver(s) and, from the front, releasing the locating/locking tab to facilitate removal of the connector pins via the back of the 14 pin connector. The pins should push out easily with no restrictions.
Step 10 ~
Now you should have all 7 wires labelled and a 14 pin connector block with no wires attached.
Step 11 ~
Now take new Abarth headlights (Series 2) and repeat steps 2-4.
Step 12 ~
Twist 8 pin connector block clockwise and remove via larger diameter hole.
Step 12 ~
Remove the purple insert (seen below) from the 8 pin Abarth connector block using a small flat bladed screw drive to release the retaining clip located at the back of the connector block.
Step 13 ~
Once insert has been removed, remove pin number 1 from Abarth connector block, using similar method to that used to remove pins from 14 pin connector. Take pin number 1 on the Abarth connector and insert into pin location 1 on the 14 pin connector, in accordance with the appropriate pictures. Repeat this process for pins 2-7 until all pins are located in the 14 pin connector. Tip – there are 2 large pins and 5 small pins so if you try to insert a large pin into a small hole then something isn’t correct so check diagrams carefully.
Name:	abarth 8 pin.jpg
Step 14 ~
Now you should have S2 Abarth Headlights with a S1 connector on it all fully working.
Connect to car and test:
- Sidelights
- Dipped Beam
- Main Beam
- Indicators / hazards
- Headlamp alignment up / down
All done!!! (Nearly)
Now repeat steps 1-14 for opposite side headlight.
Thanks Wilk0, Mads, lbhgaz, Thunderchump, nickkk thanked for this post
Old 22-02-2011   #1
Re: Converting S2 Abarth Headlights to fit S1 GP.
Just an update for anyone wanting to do this.
The Series 1 Grande Punto 2005>2008 Abarth Black headlights with 14 pin connector (ALL2169) have now been reintroduced by the manufacturer and can be purchased for £100 each + VAT from Allparts South West Ltd.
These are brand new original equipment headlights and can be plugged straight into a Series 1 Grande Punto 2005>2008 with 14 pin connectors.
They have stock at the moment but after this they will be special order items again
They also do the later Series 2 Grande Punto 2008> headlights 8 pin
Abarth333 is offline Reply With Quote Quote
Old 30-11-2011   #2
Question Re: Converting S2 Abarth Headlights to fit S1 GP.
Great tutorial im a noob here and I was just wondering if it's possible to convert S1 lights to S2?
Thanks,
Driver92 is offline Reply With Quote Quote
Old 12-02-2012   #3
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk is part of the official FF Events Team :)
Reuuk has donated!
Babe Jump Champion, Sofa Longjump Champion, Space Explorer Champion
bit of a noob question but how do i Know if mines a S1 or S2? My grande is 08plate :S
follow me on Instagram: @reuuk
Mini Cooper S & Abarth 500
Reuuk is offline Reply With Quote Quote
Old 27-04-2012   #4
Suck On Them Apples!
Enos's Avatar
Enos has donated!
Quote Originally Posted by Reuuk View Post
S2
Enos is offline Reply With Quote Quote
Old 28-04-2012   #5
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk has donated!
Quote Originally Posted by Enos View Post
S2
Old 17-03-2016   #6
Croatia
hi there, just a question, does the motor for adjusting the headlights fit from the S1 to the S2 headlight. i found the S2 headlights without the motors so i would like to swap them
xtr3m3 is offline Reply With Quote Quote
Comment
Guide Tools
(T) Help URGENTLY!!! Will Bravo/a headlights fit a Marea???? billybug Marea 7 11-01-2010 11:37
(T) will mk1 gt headlights fit... mattpunto18 Punto (Mk1) 1 12-07-2009 10:41
(G) Converting headlights for driving in Europe? Stuartl Barchetta 3 02-03-2009 08:32
(G) Converting a Sporting to a Abarth.. pic with questions spooky_fish Grande Punto 19 28-02-2008 11:25
