Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Front caliper strip and clean<!-- google_ad_section_end -->
Mute your squeeky front brakes
Published by Andy Monty
20-09-2009
Unrated
User Rated:
Difficulty Level: 1
Right i am not a mechanic so this is intended as a guide only showing how i clean my callipers ,
Obviously brakes are rather important items on your car so if in any doubt seek professional advice from a qualified mechanic BEFORE attempting any work on the braking system if your not 100% happy...... get someone who knows what they are doing to do it!
if your still not happy dont bother reading any further on....
Right thats the disclaimer out of the way
Kit needed
jack & axle stand,
wheel chocks,
Wheel brace,
*(locking wheel nut key if you have alloys)*
brake cleaner fluid,
13mm ring spanner
S hook made from a welding rod
rags,
slotted screwdriver,
Torque wrench (for refitting wheel)
gloves if you have sensitive skin
Brake grease ( i use Cera tec)
first park the car on firm level ground engage handbrake firmly and leave in gear or select park.., slacken the wheel nuts chock the opposite wheels, jack the car and support on an axle stand...
now remove the wheel and place under teh sill as a fail safe should the jack and stand fail...
Now you have exposed the caliper and disc
first hang your S hook from the front coil spring...
unplug the Pad worn indicator cable (left hand side inner pad only) by lifting the black plastic clip on the plug and pulling to remove the cars link wire. next pull the pad cables socket upwards to disengage from its mounting post..
with the cable now free unclip from its little cable clip towards the front of the calliper
get your 13mm ring spanner and remove the 2 calliper carrier retaining bolts completely (take care not to damage the brake hose a socket will not fit past it)
slide the calliper off the carrier and feed the cable through and hang the calliper on the S-hook taking care not to damage the hose
(DO NOT JUST LET THE CALLIPER HANG BY THE HOSE)
Now its out of the way the 2 brake pads simply un clip from the carrier (take care not to loose the spring retaining clips they are specific to each side so do not mix them up if you remove them)
clean the caliper, pads, disc and piston with brake cleaner and the rags use a screw driver with a rag over the tip to carefully remove any stubborn bits.
now all is clean grease teh back of the pads ((it should be obvious where the pads come in contact with the calliper) But it goes without saying do not get any grease on the friction material or disc....
clip the pads back in and put a blob of grease behind them where they clip in
now un hook the calliper from its S hook and lower into position feeding the P-W-I cable back through it
replace the 13 mm bolts and snug down then re attach the PWI cable to its cable and socket clip and plug the cars cable into it (a blob of grease on this should keep water at bay)
check the hose isn't kinked check the cable is clear of the disc and double check the 13mm bolts are tight
refit the wheel loosely
lower the car and retorque the wheel nuts then start the car pump the brake pedal several times then carry out several low speed stops to ensure everything is working correctly
its as simple as this:
(yes i know i said nuts in the video i should have said bolts )
Thanks kyle96, matty seasider, alexh365, MikeSalt, custard thanked for this post
Likes Michael Dranfield liked this post
Old 21-09-2009   #1
MikeSalt has donated!
Re: Front caliper strip and clean
Good post. One extra thing to add, with the pads out of the caliper, make sure any children / idiot mates do not get in the car and press the brake pedal. Will send the pistons shooting out, probably requiring new parts on rebuild.
MikeSalt is offline Reply With Quote Quote
Old 30-10-2009   #2
make sure its a copper greese or a high temputure grease or else your brake discs will be lubricated by runny grease
jonsparks is offline Reply With Quote Quote
Old 06-04-2010   #3
Very useful post i must say, the only thing is when i tryed to remove my hole caliper because i wanted to change the disk i couldn't get it off because the disk has warn so much there is a lip on the outside of the disk so i couldn't pull the bads over the lip. I tryed to gently push the bad back but it is so close to the disk i couldn't get anything in there.
Any help would be apresheated i know almost nothing about car maintenance but would like to learn if people can put up with my stupid questions
peter7889 is offline Reply With Quote Quote
Old 07-04-2010   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Quote Originally Posted by peter7889 View Post
watch the above you tube vid sounds like you have tried to remove the entire caliper the clue is in the 13mm bolts rather than the 17ish that bolt the carrier to the car .....
i remove the caliper body rather than the entire calliper and carrier you can pull the pads out then, then allowing you to remove the calliper carrier and subsequently the disc
Massive gash
Just a little touch up
Old 15-05-2013   #5
Hungary
I think it would be better choice the MINTEX FITTING KITS ANTI NOISE SHIM (Mintex MBA30) like this way:
img.index.hu/imgfrm/6/8/8/8/BIG_0010166888.jpg
img.index.hu/imgfrm/6/8/7/7/BIG_0010166877.jpg
szasz is offline Reply With Quote Quote
Old 22-04-2018   #6
Vatican City
Such a big blob of grease on the pads serves no purpose (you're just making a mess).
Besides that, good Guide.
GrandePunto PL is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Front bumper strip thingy. david120790 Cinquecento / Seicento 6 30-03-2009 21:27
(G) front caliper seals digger58 Ulysse 5 11-02-2009 22:43
(T) Front brake caliper ChrisMClark Stilo 11 30-01-2007 18:58
