S Stuart Prominent member Joined Jul 19, 2008 Messages 3,272 Points 671 Sep 14, 2013 #1 Whats the tech spec on these? I spied from ebay that they are stud pattern of 4x100, whats the disc size tho?
I imported_abyss113 Established member Joined Apr 17, 2006 Messages 2,136 Points 377 Sep 14, 2013 #2 gonna guess same as the grande 4x100 discs
OP OP S Stuart Prominent member Joined Jul 19, 2008 Messages 3,272 Points 671 Sep 14, 2013 #3 Which is....?
I imported_abyss113 Established member Joined Apr 17, 2006 Messages 2,136 Points 377 Sep 14, 2013 #4 well each are different depending on engine and spec but basic petrol are 257mm iirc diesel on my sporting were 287mm
OP OP S Stuart Prominent member Joined Jul 19, 2008 Messages 3,272 Points 671 Sep 14, 2013 #5 OOoOooo 4 stud 287mm.. got a link to them on an ebay set? Or do you have an old set lying about?
I imported_abyss113 Established member Joined Apr 17, 2006 Messages 2,136 Points 377 Sep 15, 2013 #6 http://item.mobileweb.ebay.co.uk/viewitem?itemId=321062143482&cmd=VIDESC
