Malfunction
Howdie all,
Just thought i would pop up this info i have just gleamed last night and tried. I have a focus type Induction kit fitted to my sei and think it is ace and love the noise and look but suffer from the common problem of the engine running hot sometimes. After a bit of investigation i have found the common problem for this and it is the Engine PCV system!
Never even herd of it till last night after a chat with a very clued up tuner.
Basically i like most removed the standard oil breather from the rocker cover and piped in a straight pip from the breather to the inlet pip on the focus kit. Then made a short pip from the intake manifold nipple to the hole in the focus kit 90% bend.
This hover means that the blow by caused by induction in every engine is not sucked out correctly by the inlet manifold. Then the carbon in the blow bye creates excess heat in the engine and drops the carbon deposits in it also into your engine oil!
I have replaced the standard breather pip now fitted correctly to the inlet manifold ( Blocked off hole in 90% bend with a bolt) and add an extra bit of larger pip to reach the focus kit.
Hay i tell you now it does make a difference the engine is running smoother and cooler, but the focus kit does not make as much of a roar now but ho hum i can live with that if the engine is working better and i am no longer damaging it basically.
Apparently this affects the map sensor also as not all the gases are now being passed through it by induction?
Hence possibly the better running as my friend recons the old setup would cause the CDI to over fuel the system which will also cause over heating ?
Just thought i would share this info as not seen anything about the PCV system on here, if it is apologies i missed it and this is a repeat.
