im Axle Specialists
Old 20-05-2020   #1
Albania
Engine Siezed
So the engine in my 500 is died (moment of silence) !
But got new engine for it for $400, and it has 60000 less km on it.
Buddy and I r changing it on wknd.
So is it hard or not ?
FiatCanada is offline Reply With Quote Quote
Old 20-05-2020   #2
varesecrazy has donated!
Quote Originally Posted by FiatCanada View Post
Probably simplest to raise body and drop engine and gearbox down..
Do (check) clutch while its a 10 minute job..
Complications will be aircon system .. and odd connections on hoses
varesecrazy is online now Reply With Quote Quote
Old 20-05-2020   #3
chris3234 has donated!
Re: Engine Siezed
Not related to the engine swap
But what happened ton the other engine for it to die suddenly?
chris3234 is offline Reply With Quote Quote
Old 20-05-2020   #4
Re: Engine Siezed
assuming its the 1.2 it shouldn't be too hard to swap. A mechanic friend of mine had the clutch out on one of these cars in about 15 minutes. (I could never do it in that time)
The aircon isn't a problem just unbolt the compressor from the engine and leave it in the car while the engine is out, should avoid having to mess about gassing the system later.
i'd be interested to know how you managed to kill the engine as well. They take a serious amount of abuse these little fiat engines.
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers can’t be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 20-05-2020   #5
Re: Engine Siezed
1.4 auto IIRC (canadadia)
Old 30-05-2020   #6
Albania
Re: Engine Siezed
I got oil changed.
Think they cracked housing but havn't got anywhere with company. Yet !
Oil light fluickered on 401 at 110kmh and as i was pulling off rd it spewed all his oil out.
Had it towed home. Filled oil engine cranked fine then a big clunk. Now nada.
Put convertible back on rd.
Old 30-05-2020   #7
I got oil changed.
Hi..
AFAIK these are multiair motors..
If its lost its oil pressure.. it cant inject fuel
There are 'parameters' that have to be met..and potentially a few things reset
Did you figure out why it dumped the oil..?
Old 01-06-2020   #8
Albania
Re: Engine Siezed
No havn't yet.
Goin threw a rough patch.
Car is parked at mothers house so havn't had access at moment for long enough.
Can i reset things or dealer have to ?
Old 01-06-2020   #9
With software on a windows laptop you should be able to perform those functions
SEARCH : 'MES' on here
Old 14-06-2020   #10
Albania
Re: Engine Siezed
Mes doesn't give me anything to do with it.
Old 14-06-2020   #11
Your North Americas spec 500 doesnt feature?
Or it doesnt support some devices fitted to it?
(T) mk2 punto engine siezed pawl Punto (Mk2/2b) 8 25-12-2014 08:46
Engine siezed Paddymorgan30 Tech Talk 9 15-05-2011 09:23
(G) Not ran in 3 years, engine siezed? mrcinquecento Punto (Mk1) 8 15-04-2008 19:26
(G) Siezed Engine 1.1 Sporting Al_200sx Cinquecento / Seicento 8 27-01-2008 21:14
(T) Spark plugs siezed in engine. brad6751 Cinquecento / Seicento 6 09-01-2004 04:54
