![]() | #1 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | My new maff Well my new maff upgrade arrived but there is no direction of flow on the case I'm assuming the I should fit it with the connector plug facing the way the oem one is but is that correct? Would a picture of it posted up help? luigi
![]() | #2 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | Re: My new maff ****......! My new maff has five pins on the connector and I have four Exchange four pin maff on the way Good job I noticed before I took the oem off LUIGI
![]() | #3 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: My new maff What is the new maff for? Have you thought about putting a turn on your turbo actuator arm?
__________________ 1.3 MultiJet Qubo re-mapped, with Cone filter. ![]() |
![]() | #4 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | Re: My new maff Hi What do yo mean I did not realise they were adjustable New maff has no mounting luggs ans it's done over 100k and I believe that's why my mpg is lower than usual
![]() | #5 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: My new maff Little trick to get higher boost pressure, you can shorten the actuator arm by a half turn or one turn or more. apparently one turn is about 1psi. I was thinking about doing a half turn for just a touch more boost, but turbo is in a very cramped position to adjust it. I also want to clean egr but in really awkward position and I think you have to remove cooling pipes and stuff to remove it.
![]() | #6 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | Re: My new maff Turbo on mine is on bottom at the front I can get to the accuator OK So..... Shorten or lengthen for more boost? Luigi
![]() | #7 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: My new maff I believe you shorten the actuator. It makes the actuator open later and under higher pressure. I got the little retaining C clip off of my actuator arm, but had trouble loosening the retaining nut on the arm as a bit awkward to get any tools in there as it's right up against the front of the engine bay in mine.
![]() | #8 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | Re: My new maff So have you done this then? As it sounds like it's all here say Luigi
![]() | #9 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: My new maff I have't yet, still trying to figure out how to get in there to adjust it without removing the entire turbo. Definitely do a little research on it first ![]()
![]() | #10 | ||
Posts: 40 Thanks: 4 Trader Rating: 0 ![]() | AFAIK Euro 4 75 hp's have a fixed non-VGT turbocharger. But i don't know if it has a wastegate actuator or something...
![]() | #11 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | Re: My new maff My turbo defo has a accuator rod on show which I can get at as in the past the accuator was sticking and kept going into limp mode Luigi
![]() | #12 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: My new maff Yeah 75 has a fixed and the 95 has a variable geometry. It's the only hardware difference I've found. I wonder how easy it would be to stick a (larger?) variable on a 75 and have someone custom map it. And whether it would be worth it :P
![]() | #13 | ||
Posts: 2,161 Thanks: 114 Trader Rating: 0 ![]() | Re: My new maff The difference between the 75 and 95 is just the turbo so your idea will be possible I had this option when I had my recon engine but thought leave it as I have a nice pokie engine with over 100 bhp with chip Luigi
![]() | #14 | ||
Posts: 3,049 Thanks: 157 Trader Rating: 0 ![]() | you wouldn't be able to stick a variable turbos onto a engine expecting a fixed one it would likely throw a eml up due to the differing boost profile's
UPDATE on MAFF's.... I can get them cheaper than shop4parts! | Tommy K | FIAT Boo Archives | 6 | 24-04-2006 13:17 |
MAFF question??!! | Tommy K | FIAT Boo Archives | 5 | 27-03-2006 13:13 |
MAFF all!! | Tommy K | FIAT Boo Archives | 8 | 13-03-2006 09:51 |
