![]() | #1 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Coilovers Hi, Been reading on here and it seems that the coilovers route seems to be Corsa coilovers, has anyone tried the C4 Picasso ones ?? The Corsa rear shocks are a no go and the C4 ones look like they'll fit ?? Any ideas Cheers Greg
![]() | #2 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | If I can up load pictures here some before and after, coilovers fitted
![]() | #3 | ||
Posts: 12 Thanks: 0 Trader Rating: 0 ![]() | Wrong way round but you get the gist
![]() | #4 | ||
Posts: 3 Thanks: 1 Trader Rating: 0 ![]() |
![]() | #5 | ||
Posts: 26,404 Thanks: 1014 Trader Rating: 0 ![]() | Re: Coilovers
![]() | #6 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: Coilovers I think my shocks or something are shot as I'm getting a clunking sound over bumps so now is a good time for me to upgrade to coilovers. What set did you go for in the end and what springs did you use on the back? I have seen that a rear punto spring has very similar spec to qubo spring except its 50mm shorter which could work for lowering a bit.
__________________ 1.3 MultiJet Qubo re-mapped, with Cone filter. ![]() |
![]() | #7 |
![]() | Re: Coilovers Sounds more like the 'broken spring' syndrome...or the 'top mount effect'.. ![]() I'd have thought elderly/tired shocks just bounce a whole lot more rather than clunking. R-V-M I think my shocks or something are shot as I'm getting a clunking sound over bumps so now is a good time for me to upgrade to coilovers. What set did you go for in the end and what springs did you use on the back? I have seen that a rear Punto spring has very similar spec to Qubo spring except it's 50mm shorter which could work for lowering a bit.
__________________ 2017 Qubo Hillbilly Azure 1.3 MJ 80PS Dualogic |
![]() | #8 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: Coilovers What should I be looking for to diagnose it? It has got worse relatively quickly from first noticing it a month or so ago, and one time there was a PING sound.
![]() | #9 |
![]() | Re: Coilovers That does sound like a broken spring. Sometimes when you corner there's a clunking as the two pieces of spring interfere under load. Best way is either take a wheel off and look or feel the spring behind the wheel (prepare for scruffy hands!) Replacement is quite a straightforward job for a garage but get both done together and ask them to change the top mounts at the same time. Not sure why you'd want coilovers but maybe they'd fit your requested suspension parts). R-V-M
![]() | #10 |
Posts: 45 Thanks: 0 Trader Rating: 0 ![]() | Re: Coilovers To be honest I like working on it myself if I can, so I would probably replace the spring and strut myself. Maybe coilovers aren't the best option, but I have been looking for a way to improve the handling and lower a little. Inner tie rods need doing as well which I'll get my mechanic to help with.
![]() | Georgemarson | Grande Punto | 0 | 16-11-2014 20:37 |
![]() | Mikey527 | Punto (Mk2/2b) | 39 | 23-07-2009 19:57 |
![]() | tim1989 | Punto (Mk2/2b) | 35 | 09-07-2009 19:20 |
![]() | LukeM | 500 | 1 | 09-06-2009 02:04 |
![]() | benpunto | Grande Punto | 15 | 23-10-2008 16:23 |
