Purchased genuine fiat wiring kit,opened the box in anticipation as to what might be in there to give me hours of grief and cussing, but know, the kit fitted perfectly all plug and play with no issues other than that its rely gear up for the qubo as you have to run a loom under the rear seats,so i just ran the loom in the void above the rear doors,and getting a feed direct to the battery was a bit tricky.
The bulb sensor feature works ok, and no cambus errors came up.
The only thing is there is no audible warning on the indicators, like on other kits i've fitted........? if anyone can advise on that small issue.
So, to some up the kit, well worth it
One other thing, you need to fit a fog light to your trailer otherwise you will get a bulb error.
Luigi
Luigi
