J
Jon
Guest
Hey guys
Opened my bonnet yesterday (Since the engine management light was on again so wanted to find a simple fix (Which now has sorted it's self out as my car regularly does)) but when I then went to close my bonnet again it clicked onto the first latch but not the secondary latch that actually holds it down fully. The handle to release the bonnet is now fully open since the cable is slack, so I'm assuming either the cable has snagged on something, or the latch it's self is jammed, I had a bit of a play with you WD40 to try and free it up to no relief. I couldn't quite follow the path of the cable to check if it were snagged or anything so wondering if anyone to give me some advice so to either free up the latch, or what direction I should be looking in to find the cable.
Thanks in advance
Jon
(Fiat Bravo 1.2L 16V Formula)
Thanks in advance
Jon
