My wife has taken the car out & i can't get to it to check, but she has told me this light has come on & will not go out. What is this a warning of 7 how do i get rid of it.
thanks for you time.
its the little yellow light of an engine that is above the hand brake warning light & the battery light. These normaly light up when you start the engine & all go out together but the engine light is staying on, the car is running normaly. any ideas?
Not sure if I can help!!! I have a Bravo and I can't find anything in the handbook which relates to the, however my bloke has a Disco and the same light on that means there is an engine fault and that it should be taken to a dealer asap
Actually read/saw an article on this recently. It is a fault light to indicate that emissions may be falling below a set standard. There are various sensors in the engine that can detect the performance of certain components - the dealer should be able to identify wich one through an error code in the ECU.
hi
ive just seen your post about the yellow engine light and ive just had the same problem can you let me know what the results of the dealer inspection were?
thanks
steve
