J
Jeremy
Guest
i got a 1.8 hlx, the cambelt tensioner went on her a while back and bent all 16 valves, got a replacement engine from a breakers, the original engine had a whining noise which i suspected was down to either the cambelt tensioner or the auxilary belt tensioner, i had new tensioners, belts etc fitted to replacement engine but whining noise is still there, only thing i figure it can be now is the alternator as the original was refitted to new engine, has any1 else had this problem, if so what was it and how was it cured, any help would be great, cheers!!
p.s. had her resprayed at the same time as engine being fitted, first pic below, more to follow!
