P
Peter Smith
Guest
Hi All
Sorry if this has come up before, I have done some searching around and found the injector is a common issue with Fiat's, but all the info I find seem to be based more for the multi-point systems and not the Bosch single point fitted to the 1.4
The problem I have is that the injector light occasionally comes on, but ALSO there is a tapping noise coming from the throttle body (sometimes louder, sometimes quieter)
I've done the redex treatment and the fault has not gone away, but the light did seem to stay off for a longer period (but this could have been psychological effect as it's a temperamental issue)
Looking at the throttle body I can only guess the noise is coming from one of the following items :
Fuel Injector
Fuel Pressure Regulator
Throttle potentiometer
Idle control stepper motor
Has anyone had a similar problem with there 1.4 Fiat, and has anyone found the fault?
Peter
Fuel Injector
Peter
