HELP PLEASE !!!!! - Light on Dashboard
C
Chris
Guest
This morning whilst braking I had a light come on the
dash , just underneath that little nob you press to reset the trip computer. It went away after a couple
of corners - everything felt fine though.
Its amber and says "STOP" and has a pic that looks like
brake lights below it. What does it mean ?
I have just had new discs and pads would that explain it ?
Is the computer confused by the new brakes bedding in?
Or does it mean by brake lights are on the blink ?
Chris
brake light bulb
is blown. Press brake pedal then jump out and run like **** to the back to see which one it is. Alternativley ask a friend to stand at the back!
alternatively
park with the boot to a wall or window and see reflection
dashboard light
If both your brake lights are ok. Check the terminals to the rear light clusters are not corroded as this can give the same problem and would be intermittant.
light on dashboard
Check the handbook to determine what the light is for
If it the brake warning light the problem could be :
A-When the new brakes were fitted was the brake fluid level interfered with?.
B- There are connections to the brake pads on the front which are failure/wear warnings and if one of them has not been reconnected properly following the brake pad replacement it can cause the light going on and off.
Don't take chances with it get it checked especially if it's the brake fluid !!.
Similar threads
J
Replies
Views
577
J
F
Replies
Views
7K
F1-ANG
F
P
Replies
1
Views
187
jords
J
E
Replies
Views
890
E
