Comment
Guide Tools
<!-- google_ad_section_start -->1.3 Multijet Turbo Check and Repair<!-- google_ad_section_end -->
Published by IanDavis
25-03-2016
Difficulty Level: 4
User Rated:Unrated
Checks
Be sure the issue is not due to a faulty boost pressure sender. Remove the turbo, complete with the catalyst. There is probably no need to separate them. Ensure no dirt enters the turbo, especially the oil inlet. Refer to header picture for part names. Check the wastegate hose for damage or splits. Disconnect the hose from the compressor housing. Blow into the end. If air flows, the diaphragm in the can has failed and you need a new turbo. If the pipe and the diaphragm are intact, use a footpump with a lilo inflating adapter to pressurize the actuator. The rod should move by 15 psi. Don't put too much pressure on it as you will rupture the diaphragm. If the rod does not move, or it moves out and not back when the pressure is released, it is sticking. Don't worry if you find oil in the hose.
Likes Scottmurphy, varesecrazy liked this post
Contents
<< <    Next Page: Repair (Page 1 of 3)    >  >>
Old 21-11-2017   #1
Re: 1.3 Multijet Turbo Check and Repair
I'm having a problem similar to this as soon as my fiat doblo 1.3 gets warm it starts to shut down at 3.5 thou rpm And smokes too. I changed the pressure booster sensor and it's stopped Smoking but still shutting down any ideas what this could be the turbo has been checked too
Scottmurphy is offline Reply With Quote Quote
Old 21-11-2017   #2
You active my friend?
Old 23-08-2018   #3
Hi, where can I find the boost pressure sensor? I suspect mine is faulty, I’m getting the turbo overspeed warning but it only happens intermittently which suggests something else.
SatSteve is offline Reply With Quote Quote
Comment
Guide Tools
(T) Bravo 1.9diesele Multijet - Check engine light JohnTzn Bravo 4 26-03-2016 21:16
(T) Bravo 1.6 Multijet '08 plate check engine issue iainfarrell Bravo 9 21-12-2014 19:50
(T) Doblo 1.3 Multijet Limp Mode No Check Light d3d Doblo 0 09-07-2013 13:14
2009 bravo 1.6 multijet automatic says check transmission jacobjohn7 Tech Talk 2 21-03-2012 17:38
(T) Punto Van 1.3 TD Multijet - Check engine light contego Punto (Mk2/2b) 15 21-07-2011 06:40
