As you have the head off I would take the valves out and "bench roll" the stems looking for any slight valve head wobble. If I were doing this job I would also do some valve lapping on all the valves (you will have to on the two replacements for the bent ones). With the lapping of the old valves you will be immediately able to see from the valve seat and valve head if there is any signs of the valve being bent (oval and non concentric lapping marks).
