Technical The problem with radio and blue&me
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
NZombi
Russia, Moscow
Hi all. I apologize in advance, I write through the Google translator. Recently bought a FIAT Croma 1.9 D 2008.in. I have this problem. No sound with Blue&Me. The phone connects, it goes to the screen of the instrument panel, the car sees USB-flash, shows the names of the music tracks on the screen of the instrument panel, but the sound on the speakers is not. In the same way radio does not turn on and off with the ignition, only by force. I would really like to get some tips from You. Thank you.
Sorry I have no knowledge of Blue and Me. I can only suggest that you get a Fiat dealer or someone with Multiecuscan to look at it. Did it ever work or was it broken when you got the car?
Robert G8RPI.
Thanks for the answer.
I have a Multiscan. I tried to make PROXY Allignment, it fails, on the instrument panel and the teleconvergence module.
When to buy a car, it did not work anymore
See if the blue and me is connected to the Radio, it's the yellow plug on the back of your radio. It's often pretty loose, so if someone was playing with the radio could be that it's not connected.
Greetings Nikolay
