im Axle Specialists
Old 06-01-2017   #46
Trader Rating: 1
portland_bill has donated!
Re: Low velocity shake
That's a good point.
The correct grease for the inner joints is difficult to get hold of. It is different from the outer CV joint grease, but most joint and boot suppliers supply the same stuff which is wrong. The inner joint should have a quite liquid grease, that almost flows, like an oozing glacier. The outer joint should use the black stuff containing molybdenum disulphide. (Sad that I didn't have to look that up!) This is the stuff that is readily available and supplied for the inners too.
Finding the correct stuff for the inner joints is difficult as it is scarce. When Rover still existed they did it in nice little sachets. I think Vauxhall do supply it in reasonable sizes.
Edit:
The Vauxhall stuff I was thinking of is for the brake caliper slider pins, another specialist grease, but usually replaced with ordinary stuff, or worse, copper grease, which is not a lubricant!
Only grease I can find for inner joints is this: https://www.merlinmotorsport.co.uk/p...ms-gkn-ms9u025
Expensive for just two joints, but significant that GKN market two different greases for inner and outer joints. Their products!
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 06-01-2017   #47
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by portland_bill View Post
<SNIP>
I'm sure the GKN grease is fine, maybe even a newer improved product but it states no solid lubricants i.e. no MD, but the Fiat specified lubricant, Tutela MRM Zero does have MD. http://tbl.onion.it/commonfile/eng/p...7_scat_ENG.pdf
The lubricant in my (1.9 16V M32 6 speed) Croma's old tulips was semi liquid with MD (distinctive colour). It only take a small amount of MD as it is actually a surface modifier.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 07-01-2017   #48
Finland
The question about grease is a good one. I'll meet the garage manager again next week and ask about it. For the pic they had washed all grease away from the tulip.
Likes tarquin1867 liked this post
ojh is offline Reply With Quote Quote
Old 01-05-2018   #49
Did anyone find the reason for this shake at 15-20mph under load and then again at 40-60mph under load? My auto has had a complete new inner & outer near side drive shaft and after fitting the shake is exactly the same. I now suspect an engine mounting (but these have been checked by the garage and I have been told they are all OK) or the gearbox diff. I consider there is too much up and down movement on the inner drive shaft where it exists the gearbox. An autobox specialist does'nt agree and they say its not the auto-box but they dont know what is causing the shake.
1fiatfan is offline Reply With Quote Quote
Old 07-05-2018   #50
anybody with this fault changed/had changed the gearbox top mount that under the battery ? After spending 3.5 hours under and in the engine bay mine seems weak and I think this might be the answer, BUT normally a car unless its a subaru with a boxer engine where the pistons are moving sideways rather than up and down should not, in my opinion induce side ways movement.
Old 12-07-2018   #51
Did any of you 3 with this problem ever find the reason ? Its cost me a lot of money to have 2 new complete inner & outer drive shafts fitted (they arrived from Italy as full units for each side, so inner and outer were already connected). Even now the car is still shaking badly when accelerating at 35-45 mph, especially uphill. I am really sick of the problem now, I even had the engine mounting under the battery removed, inspected & re-fitted, that's not the problem. I suspect the gearbox is the problem, but the autobox specialists say it cant be as otherwise the gearbox would be leaking oil as it would have blown the seals. Any help very appreciated. Remember car hit a huge pothole prior to the car starting to shake (but did not shake immediately, only after 1000 miles or so)
Old 13-07-2018   #52
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by 1fiatfan View Post
Mine was cured with a drive shaft (used Vectra C item) replacement. I think you have some kind of wheel or suspension damage from the pothole. It's no good just changing things.
The best tool for finding out what is going on is to measure the vibration. Pico Technologies Automotive NVH (Noise Vibration Harshness) is great for this.
https://www.picoauto.com/library/cas...iagnostics-kit
You should try and find a auto electrician or diagnostic expert near to you
who has this kit. A message on their forum https://www.picoauto.com/support/ might help locate someone.
I have the Pico oscilloscope and accelerometers but not their specific NVH kit, but If you are near Cambridge I'd be happy to give it a go. Someone with experience of the kit would be better though.
Robert G8RPI.
Thanks portland_bill thanked for this post
(Tu) droping a 1.6 vw velocity engine in my palio 1.2? wise or waste of time? bloop Palio 10 12-06-2013 05:39
(T) Punto constant velocity joint jte Punto (Mk2/2b) 2 16-10-2012 16:43
(G) 500 (Shake Baby Shake) sikersh 500 1 24-09-2007 19:31
(T) Termial Velocity Problem bludvl_x19 X1/9 11 26-03-2007 03:02
what make is velocity? beau I.C.E 4 27-10-2005 10:50
