Technical Croma driveshafts
Hi they are same I have car back in tomorrow for an alternator so will take a few pictures for you to show it in situ, but you would need a bracket from a vectra that bolts to the sump, by a complete one off e bay check item 291095240895
Would love to see some pictures.
I heard the same story about length when my garage contacted parts suppliers, after I'd told him it was probably a Vectra one. In the end it was a choice between a Fiat one from a main dealer for £loads or a recon job on the existing one. We got the recon, but it's been only slightly better after the "fix".
I can't understand why it wouldn't be the same as a Vectra one - it has a Vectra's gearbox and all the suspension components are GM-marked. My spare wheel came from an Astra and fits perfectly - the same offset and everything. It shares absolutely nothing wheel-related with any other Fiat.
Thanks for the reply, appreciate the info! Will have to see if I can get one delivered to Ireland! :D
...I guess that meant me.
My original driveshaft was sent away by next day delivery, reconditioned, then sent back on the third day. It was £100-ish for the 2-way delivery and recon, plus the removal/fitting by the garage.
It's rubbish and not worth bothering with. It's dumped its entire contents of grease once or twice. I've had it filled with the specified quantity of the exact Selenia grease, but it's still very twitchy.
I think the recon company was up north or midlands somewhere, I never knew who as it's a company the garage has used before so they arranged it.
A big waste of money for little or no benefit, don't bother.
So the choice is a second mortgage to get a new crappy Fiat one, or this new much more promising idea of a Vectra one.
Mine's a 16v, with the 6-speed gearbox.
We're about in Hampshire are you I travel all over uk so could drop you off what i think you need to fix your car. I note there are doubters on this site but I can assure you the gm shaft design is far better than the fiat one. I had the car in again yesterday but the battery was at fault not the alternator. But I will get some pictures to stop the doubting thomases
I have a day off work tomorrow so I'm going to fit all the parts that need doing. (Thermostat, rear discs, rear spring, front drop links, balancing and tracking) Will order the full drive shaft tomorrow and hopefully fit on my next day off. The shaking is driving me crackers!!
Wouldnt doubt you for a min- There is a problem with the drive shaft design on our model, you have cured it with a different part, whats to doubt?:p.
The original Punto/Marea set up shows that the "tulip" part of the shaft is actually enclosed in the output end of the diff, and the shaft on the drivers side is longer and appears to be supported by a bearing arrangement 1/2 way along.
If I can get my scanner to work :( I will post some pics. Its all very illuminating really(y)
Cheers for the offer - your input is extremely valuable. I should be able to order what's needed though. As I'll be paying for labour at the garage, I tend to avoid used parts and stick to new - I saw you'd linked a used part from ebay previously. My experience with the recon thing proves the point really - I end up paying for fitting twice.
Did you change both the left and right driveshafts on the one you did? Do you know what Vauxhall part numbers I'd need to buy to get mine sorted out? It's a 1.9D 16v 150BHP with the six-speed gearbox.
To throw another possibility in, I did get a PM from Granvilleb a while back saying that he'd had the "gearbox coupling" changed and it cured the issues with his.
I know nothing about mechanics, but I think this is the part the driveshaft connects to.
Is it possible that my driveshaft(s) are fine but there's another problem? I'm wondering whether we have a mix of causes here.
Hopefully these are the pages from my old Punto / Marea manual (Lindsay Porters) showing the arrangement of drive shafts for the various Fiat models ( Tipo, Tempra, Seicento, Cinquecento. Punto, Brava . Bravo, Marea& Marea Weekend.)
Food for thought?:confused:
Your garage should be able to check what is causing the vibration, the croma shaft is in two pieces it has a long shaft on the os with a tri pod joint this is the problem. I will get the part numbers for the vectra shafts tomorrow but I would go with a good second hand one, I can source the bits for you and confirm they are ok with no play and boots intact, if you like at cost, it's not a big job to swap, an hour at max. The beauty of the vectra shafts is that you can get the inner and outer cv joints easily in the aftermarket.
Thanks for the pictures the fault is with part 6 and 8 that is the tripod joint. This on a croma sits at the End of a long shaft on the osf, the NSF goes directly in to the diff on the osf it's a plain shaft about 1 foot long the then terminates after support bearing with the joint. I will get some pictures.
Cheers for your pic Chris - I have been doing a lot of head scratching about the problem with the design of the Croma tripod /tulip joint verses the one on a Vauxhall. All the while the ability of the Croma ones to lose grease has caused me most navel gazing moments.
However as I have now found my old manual it is now obvious why we have trouble and why the earlier models are relatively "bomb proof" when it comes to grease loss.
The earlier ones which are shown in my earlier pics the tulip is round on the outside profile with a lip and a location grove for the gaiter. The Croma ones are hexagonal on the outside and have the three tracks for the tripod bearings machined into the internals. No lip is present and very little location is provided for seating the gaiter . This allows for movement of the gaiter and loss of grease , its easy to see how the wear will take place (without grease) on the inside "track"within the tulip as the bearings on the tripod will be hardened to a much greater hardness than the steel used for the tulip .
The material the tulip is made from (according to my training manual) is XC45, which is pressed into shape either cold or hot . It is a similar process as making a box spanner.
I am beginning to think that we are changing the wrong part when we change the outer shaft to cure the wobble! We should change the inner one first. Guess what--- Fiat only quote for the outer !! or the pair they dont want to sell you the inner only and wont sell you a tripod either.
The "refurbishers " ----hmmm--- how can they do it by return in 24hrs??. They have access to the outer CV joints and the tripods . If the outer CV is ok they only need a pair of circlip pliers and 5mins to change that and its back in the box /van and away.:(
Have to stop now as I can feel myself getting to a high point of blood pressure and my dog is trying to calm me down:yum:
I agree with your view the one I took apart had water in it, the tripod joint was rusty, the boot was intact but as you can see on the picture the grease had been flung out due to centrifugal pressure. The reason I don't like the design is as you say the tripod receiver Is pressed like a box spanner. Not machined out of a solid piece. This is why it's so important to get te correct thick grease in the joint to take up the slack! It could even flex and expand under severe acceleration as it is only a a thin wall. Overall a rubbish design. The vectra inner joint is solid cv joint with a good cv boot design. The only answer is Change to vectra shafts. Not sure how they can recon the inner pot joint. Yes you can get the tripod separately but the pressed shaft is not really repaireble apart from welding and re machining which I doubt they will do, they will put new tripod on in an old joint with the obvious wear pattern still evident.
Right Chris I`ve calmed down a bit and the dogs asleep;).
I`m glad you found my ramblings credible(y).
I am from a metallurgical background before I retired and have a slant towards that side when I study materials parts of the car are made from. The stupidity of this design on the Croma is staggering to me. It must have been sketched out by the engineers and taken to the accountants for detailing!!!
If you were to want to make something out of mild steel plate you would mark it out on the plate using a scribe and cut it out , if it needed drilling you would mark the drill position with a punch.
The stupid thing with the design is that the tulip is not much better than mild steel and the bearing races on the tripod are harder than a center punch .
Wear internally is inevitable , and as you have found, the compounding of one mistake by another with the grease being able to make a bid for freedom at will:bang:
This thread is getting interesting, thanks to those who (unlike me) clearly know what they're doing.
Your theory that the worn part was not replaced when it was refurbed does tally with my real-world experience.
So it seems the answer is a Vectra driveshaft. Does anyone know the right equivalent part code for a 16v 1.9D with a 6-speed box?
It just begs the question - given that Fiat were already committed to using a Vauxhall gearbox and suspension, why did they feel the need to stick a different driveshaft in the middle? It's unlikely they would have had something off-the-shelf for this, so why did they reinvent the wheel when they were happy to reuse all the other GM bits?
Is there a downside to the GM driveshaft? If perhaps the type used is known for being noisy or rough or something then perhaps there would be an explanation, in that Fiat were trying to make the Croma a bit classier - e.g. it has an acoustic absorbing windscreen too. I'm not bothered if there is a minor downside, but would prefer to understand a good reason why Fiat chose to ignore a ready-made part and make their own flawed design instead.
Gm used this shaft on vectra c and saab 9 3, why did fiat used this design ? Local purchased and fiat wanted something on gage cars which was theirs! I will put part numbers on tomorrow when back at work
Ordered the GM driveshaft in the link above, (Thanks Chris) today. So, whilst doing a general service on the car today, I took the under-tray off the car for a looksee and found that there is a little oil weeping from where the OS inner shaft enters the gearbox... Is this normal if the shafts have failed?
Thanks, Matt.
