Technical cam belt day
Essex/Suffolk border
there is a rad drain pipe here
old bits
new bits
Nice post Dave
Some quick questions:
1) what was the state of the waterpump and it's mileage?
2) looks a little fiddly getting bottom belt cover off?
3) what was state of aux belt tensioner & pulleys? Mileage?
4) I see you used a Dayco cam belt kit. Were the aux belt tensioner and pulleys from Fiat or an aftermarket OEM kit?
5) How long did the job take?
it looked fine like new in side no play in it either
top 3 bolts come out from the top, jack engine up a little, bottom 2 bolts come out working under the car, lower engine a little
belt seems a little hard! rest seems ok :(
aux belt is gates, the main tensioner is oem, i didnt know we had idliers too didnt see them on s4p so they are gates fron local factors
i spent all afternoon, but did others stuff in-between, if you take off drinking 2 ltrs off coffee, lunch, doing the washing, painting some wood for shed, coming on here to see if people had answered my question in general tech section, putting dinner on ready for when mrs dave gets home from work and trying to find tools. i reckon about 2 hours.
car is on 89,000 miles it came with service stamps in the book but no lists of what's been done. top belt cover has been off before as one bottom bolt hole was split, but they may have just looked at it. not sure if the photos show it but cam belt idler has a very rough surface to it, that cant have been doing the belt much good
Based (intially) on what you have found/said I think I will go for the basic cam belt, tesioner and pully/stretcher change at 50K miles and 5 years.
Already have new aux belt which when I fitted at 36K miles/3 years and tensioner and pulleys (and belt) were in perfectly good condition.
As always I check for play/wear/roughness/etc. in all components during a job.
Your feedback is most welcome as it sets a starting point/metric on which to guage matters. Garages get to do this stuff weekly/monthly whereas we do this sort of stuff once every 3 to 5 years and in many cases on a different car every time.
Thanks for the photos - they're blooming brilliant. Crikey - I didn't know you had to undo the engine mount, makes sense I suppose.
Having skinned my knuckles changing the alternator, I think I'll chuck mine into a garage for this job, having seen what's involved.
Dear Dave
Thanks for the very helpfull pictures. I have a few questions, that I would really appreciate if you can find time to answer them since I learned from the above mentioned work description that you are a very busy person.
I wonder if there are special marks on the gear wheels and motor block that have to set in line with each order or did you just slide on the new belt at the same time as the old came off.
Why did you use the special tool visible on the enclosed picture (arrow 1)
Just out of curiosity, what is under the aluminum coloured hood (arrow 2)
Looking forward to your reply
Regards
Vento
Yes you really do need the timing tools to ensure you get everything right.
There are NO timing marks available. It would be possible to change the belt without the tools but one would have to be extremely careful, mark everything up and pray that nothing moves. If anything does move then you will need the timing tools to put matters right.
Also there is no guarantee that the person/garage who last changed the cam belt used the tools and thus your current timing is accurate. It could already be out.
Thanks Dave and S130
I start understanding the procedure. For special tool I wil take a flat strip of iron. Dril holes in the ends and place it over the crank and cam shaft cock wheel. Tighten it to this wheels whit bolts when the old belt is stil on. After this the position of the wheels is secured to each other and the old belt can be exchanged with the new one.
Keep up the good work
Vento
Vento
you also need the cam locking tool
https://www.fiatforum.com/attachment.php?attachmentid=93129&d=1312059886
the tools are only £50 on ebay and you can re sell them after
No you don't have to remove the camshaft spocket. 'Offically' one is supposed to loosen the camshaft sprocket belt to allow the sprocket to self align as the belt tension is being set (this is when you are using the proper cam timing tools).
When I did mine with the proper timing tools I bent my camshaft sprocket counter torque tool whilst trying to loosen the sprocket bolt. In the end I skipped this step because I could perfectly aling and tension the "down/pull" path without loosening the sprocket.
What is inside the hole where the the cam lock tool is supposed to be, do I need to remove a screw from it?
Is this cam locking tool in principle a rod that shift's into a hole in the camshaft?
Thanks in advance
Vento
