there 2 metal pipes next to each other left one has a rubber hose going to a sensor, the right one has nothing on it
for the boost sensor it is slightly to the left and below the EGR sticking out with a black plastic loom with a yellow clip. Single Torx 30 bolt, pull out spray carb cleaner, don't stick anything into the sensor, just carb cleaner maybe soft brush if it is really dirty, return and tighten the bolt well. My screw fell out from engine vibrations because I only hand tightened it so I had to put a different one in.
that's my boost sensor? i thought it was supposed to have a tube on it going to turbo?
sounds like i have a bird in it at about 1800 revs now and it pulls back at every cherp
dont take my word for it
im rubbish with engines im still learning
ive not noticed a noise when switch-off
when the noise comes it pulls back aswell
