im Axle Specialists
Thread Tools
Old 21-02-2011   #1
The orginal 'Old Grumpy'
Radlet6's Avatar
Radlet6 has donated!
I knew it was too good to be true
Sat idling today noticed grey smoke from under the car and a smell like a paraffin stove burning.
Any thoughts anyone?? Preferably before it is consumed in the mother of all fireballs would be nice.
AS part of the Government's new austerity measures, the light at the end of the tunnel has been turned off indefinitely.
Radlet6 is offline Reply With Quote Quote
Old 22-02-2011   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: I knew it was too god to be true
could be the engine breather hose between the top of the rocker box and the air filter box?
Massive gash
Just a little touch up
Old 22-02-2011   #3
Have you reversed over a paraffin stove?
Or is it just that the DPF was regenerating when you stopped?
I hope it's not as serious as it sounds. Good luck, let us know the outcome.
Doofer is offline Reply With Quote Quote
Old 22-02-2011   #4
the notorious one
notorious's Avatar
notorious has donated!
Serbia
It could also be the regulator bridge on the alternator, if it is car will still go but will seize soon as it's working @ half power will burn out the diodes. Happened to a guy here in Serbia last week mentioned similar smell. I suggest you check the voltage in operation right away if below standard 13.9V don't drive any more as the repair will be less although in britain they don't seem to fix the alternator just replace the whole unit (which is expensive and wasteful). Here fixing them is the norm and there are parts available.
Serbia is not suburbia.
notorious is offline Reply With Quote Quote
Old 22-02-2011   #5
Radlet6's Avatar
The alternator was new last year.
Old 22-02-2011   #6
Quote Originally Posted by Radlet6 View Post
Where it is situated, it's quite low down, so could get splashes of water now and then. There's always the possibility it was made faulty.
Do you have a multimeter? It's very easy to check, just from the battery terminals.
Old 22-02-2011   #7
Radlet6's Avatar
We'll know more next week. It is booked in for Wednesday. Will keep you posted.
I was thinking if it did go up in a ball of flame I could go and treat myself, but then I thought I would only get 2p short of f*ck all form the insurance co., so maybe not.
Old 22-02-2011   #8
I don't think you could call this forum "fanatical". It's not every car forum where someone wishes their car would catch fire.
I like it here.
Old 25-02-2011   #9
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Stopped at work after a short high speed trip from lunch and there was a terrible smell. Wife has had plumes of smoke/steam. The car hasn't turned into a fireball so I can only assume it was a DPF regen.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 25-02-2011   #10
Quote Originally Posted by Hellcat View Post
What about the car?
DPF Regen will cause white / grey smoke to be emitted from the exhaust, along with an unpleasant smell. Diesel burning in the exhaust can give a smell not unlike kerosene. The heat generated by the DPF during regen causes it to give off a smell similar to a 'fried clutch'.
HTH.
DoIDon'tI is offline Reply With Quote Quote
Old 27-02-2011   #11
Radlet6's Avatar
I suspected this, but when I suggested it to he dealer it drew a blank. As I say it is going in on Wednesday for its annual service, and they will look at it then.
Old 02-03-2011   #12
Radlet6's Avatar
Well folks here it is. The kerosene type smell is definitely from the particulate filter regenerating - so nothing untoward.
"But why the smell and the white smoke all of a sudden?" I hear you ask; and ask I did.
"Well sir," came the reply "there is a flexible joint on the exhaust which has deteriorated and is leaking slightly". So not too bad then?
However, by the medium of virtual ESP I can hear you thinking. You are thinking that this is a FIAT, there has to be a 'but' somewhere; where is the 'but'?
Keep looking.....
No it's not here.
Here it is:
BUT, the flexible joint in question is an integral part of the catalytic converter. Yes, that's right. The cat is working fine, but 20 quid's worth of flexible joint has rendered it useless.
Let's just recap here for you: FIAT take a flexible (and by its very nature vulnerable to wear) joint and instead of attaching it to £30 worth of pipe, they make it a part of an £860 catalytic converter. F******g brilliant!!
What with that, one spring and an annual service we are talking £1100. I can buy a whole f******g car from a chap in Bristol for £1400.
Needless to say I am seeking a second opinion; and failing any further joy starting a trawl of the used car dealerships (because unless the DPF is regenerating no one is the wiser). This is the final straw.
Last edited by Radlet6; 02-03-2011 at 21:24. Reason: I am well and truly p*ss*d off.
Old 02-03-2011   #13
4.5k for insurance :O
cainy1989 has donated!
pretty sure if its the 1.9 then u can use parts off a vectera/signum....could be wrrong about the exhaust side, but it does seem a few bits on the croma can be swapped
cainy1989 is offline Reply With Quote Quote
Old 02-03-2011   #14
Radlet6's Avatar
Quote Originally Posted by cainy1989 View Post
The £860 is not the OEM price - it's aftermarket.
Old 02-03-2011   #15
Trader Rating: 10
dave has donated!
cut it off, get flange and flexi from jetex weld flange on, bolt flexi to flange. i'll get link to bits, there may even be clamp on flexis
“The further a society drifts from the truth, the more it will hate those that speak it.”
Thread Tools
is this to good to be true? Vimto Rolf Auction Watch 17 24-12-2008 14:59
too good to be true? blackJTD Leisure Lounge 22 17-12-2006 22:51
Too Good to be true? OwenS Auction Watch 19 09-09-2006 17:46
(G) Too good to be true? tgobrera Other Fiats 1 07-07-2005 08:47
(T) Too Good to be true!! chrissmith Uno 5 22-04-2005 11:26
