Old 11-10-2010   #46
Re: What really is GM on the Croma????
Quote Originally Posted by uksdsgl View Post
I need front brake discs and may have to buy a steering rack for my 2005-55 1.9 16V diesel.
Do you know if there are identical Vauxhall or Saab front brake discs ...
The rear discs on my 55 1.9/16v 150hp Prestigio will need replacing for the MoT test - & Iíve already had a quick squint at the options.
Whereas the rear discs maybe common with GM models Ė I donít think the front discs are (?). Anyone?
Numbers Iíve come-up with so far are Ö
Front: FIAT 51757229
Brembo 09.9399.14 (22/05/2006) 305mm dia, max/min 28/26mm.
Rear: FIAT 46836490
Brembo 09.9505.10 (15/04/2005) 292mm dia, max/min 20/18mm.
Opel: 569114 Saab: 9191336 Vauxhall: 93171778
Caravadossi is offline Reply With Quote Quote
Old 12-10-2010   #47
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
I believe the front brakes are shared with the Alfa 159 and Brera.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 16-11-2010   #48
my croma has done 95k so maybe this is highest mileage
pottypeg is offline Reply With Quote Quote
Old 19-02-2011   #49
I might need a steering rack for a Croma diesel ...is it gm ?
Fiatcromahull is offline Reply With Quote Quote
Old 05-03-2011   #50
The orginal 'Old Grumpy'
Radlet6's Avatar
Radlet6 has donated!
The front down pipe and cat-converter on 8v and 16v diesels is common with Vectra C and Signum.
AS part of the Government's new austerity measures, the light at the end of the tunnel has been turned off indefinitely.
Radlet6 is offline Reply With Quote Quote
Old 11-03-2011   #51
Hello boys and girls. I have a 55 plate croma 8 valve diesel. It has done 99k excellently until last week when the gearbox rattled itself to bits. Its actually knocked a hole in its casing so not sure what happened. I haven't stripped it to examine it.
Back to the point of this topic. Does anyone know which other manufacturer uses the gearbox? FIAT want £1650 for a new one plus VAT, labour and fluids. Would be nice if someone confirmed same as a GM unit for half the price and more readily available. I suspect a vectra box but obviously am looking for that expert advice before I commit to any decision.
If I can't get one cheaper than FIAT then I'll be selling my car for spares/repair if anyones interested.
shrewsred is offline Reply With Quote Quote
Old 12-03-2011   #52
the notorious one
notorious's Avatar
notorious has donated!
Serbia
It's the same, there are GM numbers on it that you can copy once they have the tranny off and being Vectra C is so common you can quickly order and receive the replacement box. This is the best and safest way to get it right the first time in my opinion.
Serbia is not suburbia.
notorious is offline Reply With Quote Quote
Old 13-03-2011   #53
Radlet6's Avatar
Quote Originally Posted by Hellcat View Post
Yes and no. The discs for the four pot calipers on the 159 are different. There are two types of caliper set up for the Croma. I understand that the 8v diesel uses a GM caliper and the 16v a Fiat part (known as the Teves unit).
The FIAT part number for the pads you need is 77363627. The one for the 8v is 77363604.
However, have just searched the Girling site and they claim that there are two sizes of front disc available for the 16v Croma: a 285mm diameter disc and a 304mm diameter disc. Although EBC website claim only one at 304mm diameter. E-learn confirms what ebc say. The 285mm disc is for the 8v and the 304mm is for the 16v.
Old 08-07-2011   #54
Rear coil spring broke on my 150 prestigio and all the factors that i rang said it was listed as "dealer only", did a search and got one from a company called Hamp in Widnes , cheshire, Dealer wanted £344 for 2 fitted as they only sell them in pairs, got 1 for £46 and mobile mechanic came round and charged £20 to fit it.
blueh2steve is offline Reply With Quote Quote
Old 08-07-2011   #55
Quote Originally Posted by notorious View Post
Have been quoted £200 for a GM box from breakers, has F40 stamped on it is this the same as my 150 prestigio.
Old 13-07-2011   #56
Quote Originally Posted by blueh2steve View Post
have been quoted £200 for a gm box from breakers, has f40 stamped on it is this the same as my 150 prestigio.
no its not, see other post
Old 13-02-2012   #57
Quote Originally Posted by Radlet6 View Post
+1 Thats correct, just checked the mintex catalogue as 305's are for the 16v
Just had to do the missues front discs and pads, got an amazing deal from www.victoriaautoparts.co.uk Pads are Mintex, Discs are Allied Nippon. Some purists may say oh no what have you done, but been there and done many things with the Croma's. You get the parts while you can.
Rosso Corsa Abarth 500
Rosso Corsa Fiat Coupe 20VT.
FiatFleetFamily is offline Reply With Quote Quote
Old 14-02-2012   #58
zombie nation
Hellcat's Avatar
Trader Rating: 3
Nothing wrong with that! Any brakes should be fine, if you spend a lot more perhaps you won't have brake fade as quickly if you drive it hard.
Just had to get something around the ABS system replaced on ours. It's a GM part and means a bit chunk of the wheel needs to be replaced. Will have to find out in more detail what part has broken.
Old 14-02-2012   #59
That'll be a wheel bearing change then, the ABS sensors are integrated into them. Not too bad a job but can be pricey if you don't shop around for parts.
DoIDon'tI is offline Reply With Quote Quote
Old 14-02-2012   #60
zombie nation
Hellcat's Avatar
Trader Rating: 3
That would be the one. Didn't have time to shop around, but its replaced now so that's done.
Also had 3 of the 4 glow plugs replaced. No longer will we have a beep and 10 minutes of error messages every time we start the thing!
(G) Wiper arms for a Croma 86>92 model, anyone selling/ breaking a Croma? pietch Croma (Classic) 1 20-03-2008 19:52
