Old 25-03-2004   #1
Winning
GhostWKD's Avatar
GhostWKD has donated!
Annoying me now...
ok my car has started backfiring now
only thing i've done to the engine recently is taking (removed) a hot air feed to induction kit (for some reason had hot and cold air feeds), and now when i cruise at about 40mph in 5th it'll occasionally judder and backfire slightly (very muffled backfire) then pick up, other times its fine
anyone got any ideas what it could be? if its swapping bits over then its cool because i got my spare cinq for bit still :p
Abarth Cinq Sporting in Broom Yellow, The best colour ;)
GhostWKD is offline Reply With Quote Quote
Old 25-03-2004   #2
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Dreaded word.....ECU.
Tom (AofB)
GrpN Catback Exhaust system is here...just need to get the bleeder on now!!
arseofbox is offline Reply With Quote Quote
Old 25-03-2004   #3
Winning
GhostWKD's Avatar
*dreads* i presume if i change the ecu i gotta change the master key? and if i gotta change the master key i gotta change all keys and if i change all keys i gotta change locks?
or is it a case of change ecu over with old cinq? (and/or use the old cinq's red key and reprogram current blue keys so locks still same etc?)
Old 25-03-2004   #4
Winning
GhostWKD's Avatar
oh yeah and my induction kit is kinda (sorta, totally) very dirty B) could it be that possibly? (note: still makes the "whooosh" intake noise at bout 5k rpm upwards
Old 25-03-2004   #5
The Negotiator has donated!
Didn't it need hot and cold, hot for cold days?
Uno 1.0ie Start, oh yeah ;)
The Negotiator is offline Reply With Quote Quote
Old 25-03-2004   #6
You can just swap ECU's straight over - I'm doing it at the moment JUST MAKE SURE YOU DISSCONNECT THE IMMOBILISER FIRST! It's located directly underneath the steering colum, behind fuse box - 'bout the size of a cigarette packet - pull out wires... but obviously this = no immobiliser. But it's ok for cheaking to see if the ECU is at fault.
Hope this helps,
Matt
"No it's not a custard"
bad_boy_racer is offline Reply With Quote Quote
Old 25-03-2004   #7
Winning
GhostWKD's Avatar
was quite warm today...
Old 25-03-2004   #8
theres a sensor pipe that goes in where the normal air box would have been, when I put my induction filter on i was told to block this up or i'd have problems with the ECU being confused by it, could be sommuat like that?
other than that give the filter a damn good clean, most filters come with the cleaning sprays these days, halfrauds sell it if u haven't got any tho
dawozere is offline Reply With Quote Quote
Old 25-03-2004   #9
Winning
GhostWKD's Avatar
ok pics of it before i removed the hot air feed:
removed the pipe from zorst manifold to the induction kit, other than that the engine bay is just as it is now
Old 25-03-2004   #10
Winning
GhostWKD's Avatar
as far as im aware was working fine before removing the hot air feed, although was sometimes a bit dodgy on start (kinda not wanting to start, starting then just dying off even though i had foot on floor) then other times starting fine
Old 25-03-2004   #11
ya know the injector light, when u start the car never ever give it any revs until that light has gone out, mess's it up so fiat told me, also press the clutch in, release then start it.
Old 25-03-2004   #12
arc
this is where i stand
arc has donated!
if you're induction kit is filthy then you reckon its possible its running too rich, therefore backfiring?
the warm air feed is to stop the throttle body icing up.. not needed
Cinq Sporting - and yes, its broom yellow!
arc is offline Reply With Quote Quote
Old 25-03-2004   #13
Chris
Trader Rating: 2
Bushboy has donated!
put the hot feed back on lol and see what happenes. the original air box has one usualy. my K&N only has a cold feed tho and i have no probs. maybe u need a new air filter if its filthy lol... might not be gettingany air in
I Have A Cinq Sporting...
...Click Here To Look At It
Bushboy is offline Reply With Quote Quote
Old 25-03-2004   #14
Winning
GhostWKD's Avatar
problem is its inconsistant so difficult to test even if i was to put the hot air feed back on B)
Old 25-03-2004   #15
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Do not put your foot anywhere near the throttle pedal when starting.
It don't need it
D
Grumpy old git going fast downhill rather than downhill fast!!
(T) ANNOYING 3kRPM THING! elchinko Cinquecento / Seicento 22 07-11-2004 22:49
(G) Annoying Punto tail gate Fezza18 Punto (Mk2/2b) 7 03-08-2004 01:59
(G) very annoying rattles thefishdude Punto (Mk2/2b) 3 14-02-2004 06:42
(T) Annoying Vibration hangten Bravo / Brava 3 04-08-2003 14:11
(T) ANNOYING 3kRPM THING! elchinko Bravo / Brava 2 16-07-2003 16:16
