Thread Tools
Old 09-05-2006   #1
Trader Rating: 1
HELP QUICK, Clutch Cable
HI all, about 5 min ago my clutch cable went (Again) Can any bright spark tell me how to change it help. or at least tell me how to get the broken one off. need this ASAP plz
Paul
PS Ive got a Sei Sporting MS
warrior is offline Reply With Quote Quote
Old 09-05-2006   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: HELP QUICK, Clutch Cable
buy a haynes ...........
theres 2 bolts in to the bulkhead in the engine side
a split pin under the passenger side of the dash
the nuts on the end of the cable at the gearbox
Old 09-05-2006   #3
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
Quote Originally Posted by custard boy
except make sure it is a cinq one as there is no sei one
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
Old 09-05-2006   #4
hi friends :waves:
Liam's Avatar
Liam has donated!
Clutch cables have been covered to death, search or reregister as a girl and we'll help you!
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 09-05-2006   #5
taffy git
gaz.d's Avatar
Trader Rating: 2
gaz.d has donated!
30 secs of searching similer threads
Clutch cable
removal/refitting
NOte: ON the right hand drive models the clutch pedel is transferred across the inside of the engine bulkhead behind the facia via a system of push rods and pivots to the left hand side of the veichile. The clutch cable then transfers the effort from this point to the release mechanism. On the left handle models theclutch pedal is connected directly to the cable.
Removal
Remove the air cleaner first and its associated trunking. At the transmisson end of the clutch cable unscrew the lock nutt and adjuster nut from the end of the fitting Then release the inner and outer cables from the bracket on the transmission housing. Note the position of the damper block.
Working inside the veichile, under neath the right hand side of the facia, unhook the inner cable from the top of the clutch push rod pivot.
Returning to the engine compartment unscrew the nuts securing the outer cable flange to the bulkhead, then withdraw the cable assembly from the compartment.
Refitting
Apply a smear of multi purpose grease to the cable end fittings, then pass the cable through the bulkhead. Refit and tighten the cable flange securing nuts.
Inside the veichile hook the inner cable on to the push rod pivot.
In the engine compartment, attach the outer cable to the transmission housing and refit the damper block and nuts to the inner cable end. ADjust the clutch cable and refit the air cleaner
Taken from the haynes manual for the cinquecento i hope it can be of some assistance.
Gaz
FIAT No More
gaz.d is offline Reply With Quote Quote
Old 09-05-2006   #6
custard's Avatar
Trader Rating: 1
Quote Originally Posted by AppleSei
thought they did a pink fluffy version for girly sei drivers?
Old 09-05-2006   #7
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
nope we sei drivers might break a nail so they decide not to bother
Thread Tools
(T) Changing hydraulic clutch gearbox to take a cable clutch? 4paws Uno 10 23-03-2006 14:56
(T) Guys with clutch cable problems AIJ29 Cinquecento / Seicento 3 20-05-2005 23:08
(T) Clutch - cable or clutch itself? SnowBord Cinquecento / Seicento 12 13-02-2005 17:18
