The Cinq sporting needs its rear wheel bearings changed due to them whinning like hell and quite alot of movement when shaking the wheel by hand. The handbrake is non existant and the light in the dash also flickers on and off. The handbrake cable has been adjusted to the maximum setting so its time to replace those as well. While im doing this lot, i might as well change the drums and shoes at the same time.
This is the setup I have:-
http://eper.fiatforum.com/navi?VERS...ODE=0&EPER_CAT=SP&DV=0&GUI_LANG=3&WINDOW_ID=1
ive read in the sticky thread that the linkages should be changed also. Are these number 2 in the eper link? Is there anything else that i should change also, number 12 (sheave) for example?
