![]() | #1 | ||
Posts: 74 Thanks: 2 Trader Rating: 0 ![]() | Front spring rubbing bodywork Seicento 2001 Hi, My front o/s spring occasionally rubs against the bodywork on the inside of the wheel well. Happens when I'm going lock to lock eg when parking. It's as if the spring is either warped or out of alignment. Has anyone experienced this before? Any tips/advice other than removing the strut and changing the spring? Thanks PC
![]() | #2 |
Posts: 23,487 Thanks: 1152 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Front spring rubbing bodywork Seicento 2001 Top mount seized/misplaced? D
__________________ |
![]() | #3 | ||
Posts: 404 Thanks: 16 Trader Rating: 0 ![]() | Re: Front spring rubbing bodywork Seicento 2001 have you been able to see the spring moving? Does it behave differently on the NS..?
![]() | #4 | ||
Posts: 74 Thanks: 2 Trader Rating: 0 ![]() | Re: Front spring rubbing bodywork Seicento 2001 Hi, No, not had a look at the spring moving as need somebody else to turn the steering wheel while I look. What are you thinking? What should I look out for? I understand it just turns as you turn the steering.
![]() | #5 |
Posts: 3,295 Thanks: 251 Trader Rating: 0 ![]() | Re: Front spring rubbing bodywork Seicento 2001 The spring must either be fractured, or the top mount has collapsed. You need to remove the damper (it's just three bolts) and have a look at which it is. Ralf S.
__________________ No bullets for chaingun |
![]() | surfamakikomi | Grande Punto | 11 | 13-08-2014 10:21 |
