Old 09-05-2019   #1
Denmark
Suspension setup
So I have recently gotten my Cinq on the road and though it is great fun, I find cornering a bit to wobbly and not flat.
I had Ta-technix -40 springs and dampers installed not to long ago plus a front strut brace, so seeing this was quite unexpected.
Would I be able to simply change the springs in order to get flatter cornering (Not really to bothered about comfort), and in that case, what brand should I consider?
Thanks.
Cinq11 is offline Reply With Quote Quote
Old 09-05-2019   #2
Re: Suspension setup
Check bushes etc before thinking it's bigger suspension components
Sent from my CLT-L09 using FIAT Forum mobile app
curtisjwc1 is offline Reply With Quote Quote
Old 09-05-2019   #3
Denmark
Will do. There's a horrible knocking sound coming from the rear suspension whenever I go over a slight bump on the road. Thinking it might be the bushings
Old 09-05-2019   #4
Trader Rating: 1
Kw coilover setup is good, definitely not wobbly.
Likes Cinq11 liked this post
Brooky is offline Reply With Quote Quote
Old 09-05-2019   #5
Check the trailing arm bushes- mine were doing that and they were down to metal on metal. If you want to go down the polyurethane route, Strongflex are popular and well-priced.
Thanks Cinq11 thanked for this post
Jamieboy is offline Reply With Quote Quote
Old 10-05-2019   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Which Cinq do you have, Sporting or otherwise.
Definitely get the rear bushes done, they lead to rear instability, but will not get picked up at an MOT.
D
Old 10-05-2019   #7
Denmark
A Sporting. I recently had my MOT but he really didn't seem to bothered about anything. I suppose the very loud knocking sounds coming from the rear is the rear bushes. I just bought a Strongflex kit, so I'll have that sorted
Thanks.
Old 10-05-2019   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Do you have any adjustment on the spring pan? I am unaware of that brand of suspension and the web information is a bit light.
D
Old 10-05-2019   #9
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Quote Originally Posted by rallycinq View Post
D
Guessing it's this one? https://www.tatechnix.de/tatechnix/g...0-40-40mm.html
Eklipze3k is offline Reply With Quote Quote
Old 11-05-2019   #10
Denmark
Yup. Fairly cheap, but still seems a good mix between comfort and stiffness (though my spine would disagree).
Old 13-05-2019   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Not a lot of info on the damping....in fact...none, nor spring rates....difficult.
Try it without the front ARB
D
Old 17-05-2019   #12
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
end of the day, cento's lean, alot. Even trofeo rally versions if you watch them have mega lean. To get it to stop leaning is a tall order but not impossible. But you aint gonna do it with off shelf parts for sure. I'd not worry about the lean though, they handle pretty decent with good suspensiopn and stuff.
As above, its not a new car by any stretch and lots of the bushes will be original no doubt. The rear arms can be knocking like absolute buggery and still not see any noticeable movement when checking like on an MOT.
Go through and replace basically all the bushes and it will feel nice and tight.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
(T) Stilo 1.2 - Abarth Suspension/Steering Setup nikiforos83 Stilo 13 06-03-2017 09:51
(T) Advice needed for Suspension Setup Joeguard1990 Punto (Mk2/2b) 11 28-07-2010 11:35
is the suspension setup the same as a alfa 156 or coupe 20vt? calvert FIAT Boo Archives 2 03-11-2007 18:34
(T) suspension setup freeskier219 124 Spider (Classic) 2 28-10-2007 04:15
(T) Do later Sei's have different a rear suspension setup? arc Cinquecento / Seicento 9 16-09-2005 10:59
