- Oct 9, 2006
- 774
- 227
need to replace clutch set in my 2001 1.1 MPi Sei Brush, its really hitting the end (clutch pedal free travel is only some 1 inch) and changing gears is bit "shaky"(not hitting teeths yet), need to done job together with new clutch cable and want to order parts sooner as need to get the job done in 1 day -
do you have any knowledge which clutch bearing and which cable length will fit??
EPER is showing 540mm cable by code is this right?, but there is 2 clutch bearing options - simple bearing and some bearing with "wings"-which should fit?
Clutch disc and clutch pressure plate will be no difference betweens centos I think? Is LUK/VALEO clutch sets any good (much cheaper than SACHS)??
Thanks!
(LUK sets pictured)
Thanks!
(LUK sets pictured)
