Miller Corner
Member
- Nov 6, 2018
- 11
- 78
Hallo you lot!
Firstly yes, it's me off YouTube - heyya!
Secondly, the Super Seicento is indeed BACK and now ON THE ROAD!!! :slayer:
Thirdly, with the cosmetics gradually being done over winter, I'm thinking about power upgrades in the new year. Currently running the following spec:
1242 8V
866 Cam
42mm Ported TB
4-2-1 Stainless Manifold
High Flow Cat
Sportex Catback
Unknown Brand Cold Air Intake
Makes all the right noises and makes me grin like a madman, but I'd love a bit more POWWA. Naturally I've jumped to turboing the little beast and for its size, availability, affordability and general aftermarket support, the Subaru TD04 seems a good bet (comes on WRXs, Forester XTs and I believe some Legacies...? :shrug:
If I were to run with the TD04, a few questions for those of you with turbo 8V experience:
This is all off the top of my head atm - money, time, space and life generally would all be limiting factors, but as much prior info as possible would be greatly appreciated
Other than that, have a good one! ;D
1242 8V
866 Cam
42mm Ported TB
High Flow Cat
Sportex Catback
- Would the standard WRX intercooler be sufficient? (front mounted)
- Which injectors would be best suited to around 120-130 @ the fly?
- Upgraded pump/fuel pressure reg presumably required? Suggestions?
- Assuming a stock Cento clutch would give out at this stage? Can anyone confirm rumours that a Stilo 1.4 16v/Panda 100HP clutch works, or is another upgrade preferable?
