Thread Tools
Old 11-10-2018   #1
Hungary
Alternator rebuild
I have a 2001/12 Schumi. After around 6 - 10km of normal quiet driving, an awful screeching/metallic grinding sound occurs. It's really loud! When the engine is turned off and left for around 1 hour, starting and driving are all quiet once again until the above kms are reached. The local garage says that the alternator is kaput. They claim that they can't find another one and want to rebuild this one...at the cost of 100! I see loads of ads for Seicento alternators. Am I missing something? Can I use any alternator from a vehicle of the same year? Also why would something make a noise only after the engine is warmed up? Thanks in advance.
Little Lamb Found is offline Reply With Quote Quote
Old 11-10-2018   #2
Re: Alternator rebuild
the parts to repair the alternator yourself can be got pretty cheaply. its not too bad a job to do, but you really need a press to get the bearings on and off.
any alternator off ebay that suits the engine you have in your car should do fine. they range from about 30 used to around 60-70 for a refurbed unit.
tbh, if you are getting a garage to do it, 100 all in isnt a million miles out for supply and fit of a recon unit.
the bearings are no doubt dry. once it has a bit of heat in them, they will make a noise. its pretty common and wont get any better unfortunately
dac69er is offline Reply With Quote Quote
Old 11-10-2018   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Easy way to confirm the diagnosis is to take the alternator belt off at the impact temperature and see if the noise goes away.
It could be the bearing on the cambelt tensioner.
D
Old 18-10-2018   #4
Don't leave it too long...
My Stilo had squeaking bearings that matey mechanic said was the alternator bearings, same as yours. The choices, he said, were either to change it when it was convenient for me, or when it fails completely. Obviously I chose "later" rather than "sooner"..
The bearing eventually collapsed altogether and came off the spindle. I had enough juice in the battery to get me home but the RAC fella had to lever the aux belt off the pulley so that it didn't try to mash what was left of the pulley into the chassis rail..
A new alternator (i.e. a refurbished one) is probably a better bet than fixing the old one, since a refurb is "all-new everything" (apart from the non-moving brackets and frames etc. which would be cleaned up and essentially look like new anyway...) including the regulator/rectifier, the windings and of course the pulley... whereas just fixing your pulley for the same price means your alternator would still have the old regulator/rectifier and windings etc. The regulator/rectifier (when it fails) also costs the same as the recon'd whole alternator... so it's a no-brainer to fit an all-new item rather than just replacing the bits that have failed.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Thread Tools
(T) Alternator rebuild kit? Alex74D 500 (Classic) 2 29-12-2015 11:29
(T) Rebuild owen1993 Cinquecento / Seicento 1 03-02-2013 11:47
(T) After the rebuild JakeF 500 (Classic) 23 01-02-2013 05:35
(G) The Rebuild! danny hgt Punto (Mk2/2b) 8 16-03-2007 21:31
