That's good news - if the heads are identical that must also mean that the 1368 pistons, even though bigger bore, have similar pop-up shape to 1242 pistons, above 'deck' (where they rise into the head's combustion chamber), should clear the valve heads, and should give same CR as a 1368 motor, even tho using a 1242 head. Does that sound right?
What about our hope that the unaltered 1242 sensors and ECU will compensate for any effects of the bigger capacity? Should we increase fuel pressure a bit?
