Old 30-06-2005   #1
Netherlands
Self Learning ECU
They say that the Cinq ECU is self learning but what?
Under what conditions will it learn and what will it do.
Greetzz Dennis
TurboCinqy1250 is offline Reply With Quote Quote
Old 01-07-2005   #2
Lightbulb Re: Self Learning ECU
when you change a part connected to the fueling/exhaust system, such as an induction kit, the ecu takes a few miles to calculate the air/fuel ratio at a given throttle position and then adjusts the ignition timing to maximise effieciency. whereas on a car with carbs you would have to run dyno tests, then rejet the carb and change the timing manually to stop preignition or over lean running, the ecu on an FI car works all that out for you.
It also means that your car runs like a bag of poo for a while before you get any real performance gains.
project-cinqy is offline Reply With Quote Quote
Old 01-07-2005   #3
Ah. Not good...
chaos's Avatar
Trader Rating: 3
chaos has donated!
League Bowling Champion, Bikini Bounce Champion, Bowling tgfg Champion, Island Bowling Champion, Lawinen Surfer Champion, Missing Link Champion
Quote Originally Posted by TurboCinqy1250
Greetzz Dennis
The ECU needs to reteach itself after a power interruption (e.g. when the battery is disconnected), as well as engine mods.
This means that it optimises fuelling, sparking etc automatically over IIRC about 250 miles. So for the first 250 odd miles your engine may be rough running as the ECU is trying to optimise itself.
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline Reply With Quote Quote
Old 01-07-2005   #4
hi friends :waves:
Liam's Avatar
Liam has donated!
I'll add that the ECU will have programmed limits which it will not exceed because it will think the engine is being damaged.
You will need a re-programmed chip of piggyback ecu to get the benefit from more extreme tuning, hence the need for the MF2 in some turbo conversions.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 01-07-2005   #5
HP
I was only doing 80...
HP's Avatar
HP has donated!
It'll only adapt so far, it's still running within the confines of a standard 1108cc map. You'll always get better results from a custom map designed for your setup.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 01-07-2005   #6
Netherlands
Quote Originally Posted by project-cinqy
Is this in closedloop mode or openloop. With Lambda or Without.
I thought that full throttle always the values were from the chip inside.
So if I change some values with a piggyback like the SMT-6 the ECU still tries to correct it?
(T) ECU repair ? ndroz2003 Uno 2 16-09-2008 21:22
Cinq ECU to Punto 75 ECU TurboCinqy1250 Lets Talk FIAT 23 24-07-2005 18:20
(T) ECU and immobilisers arseofbox Cinquecento / Seicento 0 11-06-2004 01:24
Indep Fiat Specialist with ECU Diag Eq HULL rsmallwo Lets Talk FIAT 0 11-03-2004 01:30
