hello people of the Cento section.
this one is currently seeking a diagram/schematic of the wiring loom of an 6F ECU cinquecento for a sort of "modernising" project. if anyone has one, can they please post it up... or PM it me... thanks
Or.
if someone knows,
if you were to remove the 6F ECU and wiring loom from the engine you have 2 connectors that go to the car's wiring loom
one is a single wire connector, next to the passenger head light (quite a thick cable so i assume it is a live power input for the ECU and loom)
and the other is a 3 pin connector next to the battery tray going into/behind the dash. (i assume that one wire is an ignition live, one wire i assume is connected to the "injector / ecu" light, but the 3rd wire i have no idea what it goes to
can anyone tell me what cable goes where, preferably by cable colour?
for those who do not know, i am converting @420's aka my brother's Seat Marbella to SPI. it uses the same(ish) engine as the cinquecento only its the older 903cc.
it is some crazy hybrid ECU controlled carburetor system that was designed to stop a carburetor being so wasteful to pass new emissions laws (yes, it has a carb.. with a catalytic converter.. choke and everything!). however.. it has broken and will eventually wreck the cat converter
See this post here for more details
Thanks guys!
Or.
if someone knows,
Thanks guys!
