Thread Tools
Old 04-04-2012   #1
Denmark
Seicento 1.1 MPI ECU pinout
Hi.
I am building a new engine for my seicento and want to replace the original ECU with an Vems ECU.
By this way i need the Magneti Merelli IAW 59F.M1 ECU pinout.
Can any one please help me with that? I cant find it anywhere.
Thanks in advance
Kind regards
Jonas Pedersen
Denmark.
jonasp is offline Reply With Quote Quote
Old 04-04-2012   #2
Trader Rating: 5
fingers99 has donated!
Re: Seicento 1.1 MPI ECU pinout
Not sure that the pin out will help.
There is one in the Sei Technical Manual (downloads section) but may onl;y be for the horrible and nasty micro ECU, rather than the wing mounted jobbie.
Anyway, try Volume 4/Section 1/Engine Command.pdf
M12 fund £20
fingers99 is offline Reply With Quote Quote
Old 05-04-2012   #3
Denmark
Hi.
As far as i can see, this is only for the SPI engine. My engine are the MPI model.
/Jonas
Old 05-04-2012   #4
Trader Rating: 5
It is there for the MPI as well. Or it should be. Ming posted it I think from a CD he'd bought from me . See the 4 injectors?
Not sure if the wiring colour changed between the early (mini ECU) and later (wing mounted ECU) MPI cars.
If stuck, PM me with your email aqddress and I'll try and forward the most relevant schematics I have.
M12 fund £20
Old 05-04-2012   #5
Trader Rating: 1
give me your email i will send u pinout
kyller is offline Reply With Quote Quote
Old 05-04-2012   #6
Denmark
You got mail
Old 07-04-2012   #7
Denmark
Still need pinout or full documentation.
some one in here must have replaced et original ecu on an seicento mpi?
/Jonas
Old 07-04-2012   #8
Trader Rating: 5
Therer maybe something in one of Kripit's posts. I know he was looking at a direct plug and play set up for Megasquirt using the big fat AMP connector on the original ECU.
But I really can't see what you need a pin out for, or what fuller documentation you can have than the factory wiring diagram!
M12 fund £20
Old 07-04-2012   #9
100% fiat addict
mariocinq's Avatar
Trader Rating: 2
mariocinq has donated!
sounds like he needs to know which pin does what, ie pin1 to map etc etc i have had a similar issue on my dads autograss buggy when trying to fit an after maket ecu to the standard loom. sorry i cant help with the diagram but that sure clear up what the OP wants it for.
Fiat,Its not just a car, its an obsession
2005 Vauxhall Zafira SRi 2.2
2003 BMW 320d
1999 MGF
mariocinq is offline Reply With Quote Quote
Old 07-04-2012   #10
Trader Rating: 1
i will sent it
but i have to find it before :-)
some patient
Old 07-04-2012   #11
Trader Rating: 5
Quote Quote:
Sure. But there's nothing there that couldn't be very quickly snagged from a wiring diagram or a wire trace with a multimeter.
M12 fund £20
Old 07-04-2012   #12
100% fiat addict
mariocinq's Avatar
Trader Rating: 2
Quote Originally Posted by fingers99 View Post
true true but guess he is looking for the easy way out like i did with my dads autograss buggy lol but thats had 64 wires on 2 sperate ecu's to trace lol
2003 BMW 320d
1999 MGF
Thread Tools
(T) Punto Multijet ECU Pinout?? Haffisig Punto (Mk2/2b) 1 04-09-2011 10:51
(T) MPI Schumacher Seicento ECU and Coil Q? SchumacherSeicento Cinquecento / Seicento 10 05-11-2009 16:08
(T) Seicento MPI ECU standards? ODB,ODB2? kritip Cinquecento / Seicento 2 15-02-2007 08:40
(T) seicento mpi ecu fault codes shnowzy Cinquecento / Seicento 5 24-01-2006 08:34
