C craigk Member Joined Feb 26, 2011 Messages 453 Points 96 Mar 5, 2011 #1 hi i am just wondering if a seicento drive shaft along with cv's etc will fit a cinquecento?
craigb244 Patron member Parked in the garage Written a guide Joined Nov 1, 2007 Messages 5,853 Points 858 Location Bridgnorth Mar 5, 2011 #3 as long as they are from a sporting (if its for a sporting) and they are the dry type not wet basically if its the from a sei of the same size engine and they look the same then it will be fine
OP OP C craigk Member Joined Feb 26, 2011 Messages 453 Points 96 Mar 5, 2011 #4 craigb244 said: as long as they are from a sporting (if its for a sporting) and they are the dry type not wet basically if its the from a sei of the same size engine and they look the same then it will be fine Click to expand... my chinquecento is a sporting but the driveshafts are off a seicento 1108 sx ?
mrcinquecento Stick your own title Parked in the garage Joined Apr 15, 2008 Messages 7,033 Points 1,032 Location Dundee Mar 5, 2011 #5 craigk said: my chinquecento is a sporting but the driveshafts are off a seicento 1108 sx ? Click to expand... they will fit.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Mar 6, 2011 #6 Some 1108 Seis have the wet inner shafts, but there seems to be no rhyme or reason to which is fitted to which. Cheers D
