Old 17-01-2011   #1
seicento fuel tank removal
Hi does anybody know what is involved in the removal of the fuel tank on a spi seicento. my friends car is leaking when about half full and needs it changing asap. Can anybody give me some pointers please..
mobile360 is offline Reply With Quote Quote
Old 17-01-2011   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: seicento fuel tank removal
Make sure its as empty as you can.
Spray Plus Gas on the rear bolts twice a day every day for a week before starting the job.
Lift the diamond panel under the rear seat and carefully pull the electrical connections.
Undo the nut that holds the supply and return pipes and lift them clear.
Get the car in the air supported on axle stands, always give it a shoogle before getting underneath.
Undo the filler tube from the tank, make sure their is a catch can underneath it to cath the fuel thats left.
Release the exhaust from the rubber mountings, the flexi will allow you to get it far enough out of the way.
Support the tank as you undo it, you can try and drop the nearside first as this will keep the fuel in it.
Once its out, remove the sender, half a turn gets it out. Undo the wee bolts and lift the pump assemby out. You will not get the pump out without lifting the sender first.
Replacement is the reverse of removal as said in Mr hayne's book.
D
Thanks mobile360 thanked for this post
Old 17-01-2011   #3
Trader Rating: 3
ycming has donated!
Thanks for that, sounds easy in taking the pump out, any other thing i should watch out for ?
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 17-01-2011   #4
David C has donated!
When I did mine, I syphoned most of the fuel out via the filler.
The remainder I carefully drained from the tank with the filler tube disconnected.
You can get most of it out by tilting the tank.
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 17-01-2011   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by ycming View Post
Ming
Nope.
D
Old 17-01-2011   #6
Check your front to back brake pipes whilst the tank is off,if they're corroded it will save a packet if you can do it your self
donttalkrun is offline Reply With Quote Quote
Old 17-01-2011   #7
Trader Rating: 5
fingers99 has donated!
From memory the Sei one will woggle out comlete with sender (the Cinq one won't).
The Sei tank may be done under a recall -- phone FIAT HQ with your vin number.
M12 fund 20
fingers99 is offline Reply With Quote Quote
(T) fuel tank removal Job13 Cinquecento / Seicento 6 03-08-2009 16:10
(T) Seicento 98 Fuel Tank chrisharp03 Cinquecento / Seicento 6 16-03-2009 00:10
(G) seicento fuel tank walks Cinquecento / Seicento 4 27-09-2008 19:23
(G) Seicento fuel tank willie1505 Cinquecento / Seicento 6 10-05-2008 16:20
(G) Seicento Fuel Tank branton rhino Cinquecento / Seicento 14 03-01-2008 01:07
