peaster2k Established member Written a guide Joined Jan 19, 2004 Messages 1,323 Points 348 Location Washington, United Kingdo Jan 20, 2005 #1 Does anyone know the thread size of the bolts that keep the Cam Cover on? Thanks David
DJ_Bucho Established member Joined Aug 2, 2002 Messages 620 Points 198 Location Co. Durham Jan 20, 2005 #2 Mate the bolt size you need is M6x1 (meaning the threaded part of the bolt is 6mm wide and the threads on the bolt are spaced 1mm apart). HTH Brian
OP OP peaster2k Established member Written a guide Joined Jan 19, 2004 Messages 1,323 Points 348 Location Washington, United Kingdo Jan 20, 2005 #3 Cheers Brian, i knew you would not forget David
