I swapped my clocks over from my old car that was written off as the new ones have really flaky paint on the dials, this isn't exactly a fun job but the mileage isn't much more on my old car than the new one so was willing to put up with a slight increase.
Now the airbag light will not reset at the local dealer in Nuneaton
Does anyone out there know if the Airbag unit is linked to the main ECU in any way?
I'd rather avoid swapping the clocks back, but the guys in Nuneaton are suggesting I'd need a new airbag control unit costing way over £200 or possibly that it could be an ECU fault (although I know the only thing I have done is swapped the dials over with the battery off).
I'm thinking that if the Airbag control unit is completely seperate to the main ECU then I could just swap in the control unit from my old one if it needs to match up with the clocks??
