![]() | #1 |
![]() | MOT Prep right heres the list front windscreen all round suspension bushes and arms and rear shocks new front pads and discs new rear brake cylinders 2x new h/light both front cv joints (will be taking shafts out completely to help with outer boot fitment as i need to drop the g/box oil anyway) h/brake cable ARB bushes is there anything i should know/take into consideration about any of the above. as some of you know i am a time served spanner monkey but HGV is my area not cars. im particularly interested in techniques removing and refitting front and rear suspension arms. thanks in advance guys and girls
__________________ Rich '02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks. '99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust. |
![]() | #2 |
Posts: 3,254 Thanks: 120 Trader Rating: 0 ![]() | Re: MOT Prep Dont replace the rear arms push out the bushes and push in new ones, if you have access to hyd press easier, possible with engineering vice. You do need to remove them of course. Noel
__________________ standard Sei Sporting except for colour matched ice scraper, screw driver, & steering wheel lock i.e yellow car spare alternator belt, clutch cable & bulb set, 2x overalls |
![]() | #3 |
![]() | Re: MOT Prep ... bushes are shagged got good bushes in a set of arms since id have to remove the arms anyway they can be my spares for putting powerflex in ![]()
![]() | #4 | ||
Trusting in Jesus Join Date: Jul 2009 Location: Peterhead
Posts: 110 Thanks: 9 Trader Rating: 0 ![]() | ![]() Hiys mate, I have recently done a largish resto on a 2001 (!) siecento, and thought i would throw in my lot for the Handbrake Job ~ the arms that it connects onto are like a right angle elbow on a basic~pivot... They may be siezed and look like needing replaced.. Don't be decieved, they are not cheap to buy new, but with a file, some oil, and 20 mins of patience they will be as serviceable as new... Even if they aint too bad, deffo get 'em out and make sure they work Freely... Since you too are mechanically practiced i shan't bore you with stuff about SAFETY and wirebrushing n WD40 the day Before ! Paul ![]() ![]() ![]() ![]() ![]() ![]()
![]() | mm3snipe | 124 Spider (Classic) | 1 | 05-11-2008 20:42 |
![]() | L8AGN2 | X1/9 | 0 | 11-02-2008 05:54 |
![]() | custard | Cinquecento / Seicento | 0 | 22-02-2007 16:51 |
![]() | SkinzCinqSporting | Cinquecento / Seicento | 16 | 18-09-2006 13:58 |
RALLY prep cinq | chubbston | Auction Watch | 12 | 25-07-2005 19:31 |
