Hi
1. You quoted a previous post
But in
this thread Pep0 states its should be "75W/90 oil to meet
API GL5 & Mil-L-2105D specifications"
that was from the FIAT SPI sporting handbook, I have checked I typed it ok.
2. You may find a lot comes out after you fill it, I donno what I do wrong to get this.
When I drain I start with (a warm gear box) the car nose down a slope trolly jack and axle stand back to level pull the drain plus leave for 30 mins, drop the car back down, leave for 30 mins, jack it back level and fill, leave to dribble for 30 mins, lots of new oil seems to come out.
When I put the plug back I start the engine and run the box in gear, stop it and try adding some more, this is for my other cars that have 'shelves in their boxes that pool oil'.
3. Some boxes may have a small magnet embedded in the drain plug, it will have attracted lots of metallic swarf, if you drain it when the oil is hot you will get more of the non ferromagnetic crud to come out with the more fluid oil.
4. I got a 2nd hand low mileage sporting box for 55 GBP, from a forum member. My box makes strange noises, like shot final gears...
Noel
If the plastic bottles that the oil comes in are cold it is more difficult to squeeze them, David's suggestion is a really good one.
