im Axle Specialists
Thread Tools
Old 31-10-2004   #1
Unhappy 'Monster' Water Leak
Just when I'd gotten used to my cinq sporting dumping water on my foot when I filled the washer bottle and topping up the expansion bottle from the small rad. leak, I have now developed a more worrying leak. Water is coming out of somewhere at the back of the engine, though I can't see where. It's using about 1/2 litre every 8-10 hours, and is dripping out when the car is stationary. (I can't check when I'm driving)
I make sure it is topped up to the max mark in the expansion bottle and it will be going in the garage in the week as I am mechanically inept, however, I would like any suggestions as to what it might be. It drives fine (I do 200 miles a day in it), doesn't overheat and, but for the fact that it leaves a small pond wherever you park it, behaves fine.
Am I looking at something terminal or is this a 'common' problem? Any help/info would be gratefully received. Thanks. DeeDoubleYoo.
DeeDoubleYoo is offline Reply With Quote Quote
Old 31-10-2004   #2
hi friends :waves:
Liam's Avatar
Liam has donated!
Re: 'Monster' Water Leak
I had something like this last year, it was a leak in the hosing behind the TB and it was the plastic connection that connects two or three different hoses that had perished, I fixed it with a part from an Uno but it didn't last very long.
I got a new hose section from the Sei and the junction is replaced by a moulded pipe.
Cost 28 from Fiat and took a couple of hours to fix due to space being tight back there.
HTH
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 31-10-2004   #3
Thanks for the reply Liam. I hope mine proves to be the same and not too expensive. Thanks again. DeeDoubleYoo.
Old 08-11-2004   #4
Smile Re: 'Monster' Water Leak
Hi Liam,
For info., Problem was exactly the same as you experienced and is now resolved, without a huge bill.
Thanks again for your advice.
DeeDoubleYoo
Old 08-11-2004   #5
hi friends :waves:
Liam's Avatar
Liam has donated!
Wow, actually right on something for a change! Pete will be quaking in his boots! LOL
Not a problem, did you get the uprated part?
Liam
Yes it's really me!
Old 09-11-2004   #6
Hi Liam,
Not too sure about the uprated part but I did give the mechanic your reply so would presume he took heed. He even fixed the washer bottle so I've got a nice clean windscreen and no wet feet when I attempt to fill it at the garage!!!!!!
Hopefully that's the end of my 'aquatic' problems and I can move on to the 'squealling' noise which he thinks is the 'pulley' bearing. Anyway, that's for the car's next visit.
I'm finding the cinq incredibly resilient, given that I'm using it to commute 1000 miles a week, the sort of job I'm sure it wasn't designed for.
Once again thanks for the help. No doubt I'll be back in touch when the next 'mystery' problem emerges.
Dave.
Old 10-11-2004   #7
hi friends :waves:
Liam's Avatar
Liam has donated!
Quote Originally Posted by DeeDoubleYoo
Dave.
Yeah, they can take some abuse if cared for at the same time.
If you do pop back even if I can't answer your question someone else will.
Liam
Yes it's really me!
Thread Tools
(T) water leak in passenger footwell blackpool_uk Punto (Mk2/2b) 9 15-12-2004 22:07
(T) Water Pump major leak red_cinqo Cinquecento / Seicento 2 26-10-2004 00:10
(T) Radiator / Water Leak pyrrho Punto (Mk2/2b) 5 22-07-2004 22:52
(T) water leak jeppef Marea 2 09-04-2004 03:38
(T) Tipo water leak...in the cab gavnotts Tipo (Classic) 1 14-03-2003 08:10
