mdsremos
We thought we had a radiator leak as there was a few marks under the car whenever we came to it each morning, took it to Mangoletsi for the fuel tank recall (its a 99 T reg Seicento Sporting) and asked them to take a look. They mentioned it was a clip that needed replacing near the rocker switch and they would charge £55 plus vat to sort it. Decided to wait a little bit till we got paid and take it somewhere else but noticed a major leak last night and put a cup under to catch the drips and it was overflowing this morning with pink cooler fluid and the cooler tank is way under minimum!!!
Put the car on axles, removed the protective cover to the left of the underside and know the area its coming from but cant see any pipes it might be leaking from....dont even know where the rocker switch is if it is the same problem that is.....did notice the sort of metal cannister type thingy and the leak is dripping off it to the right (as your looking under the car) but reluctant to start taking covers off things in case we remove the wrong part. Have followed the cooler pipes from the tank but still cant see where its leaking.
Anyone got any ideas.....Hubby is at the end of his tether and wants to just sell it but we've spent loads on it already so feel unsure at the moment.
